    Aug 2009
    wales
    45
    2
    electronic controller inside
    worked on a split unit today, elliwell controller internal with nothing running out the switch compressor on and off, evaporater comes down to 1 deg then rises to 4 deg then back down to 1deg, compressor never cut out the hole time i was there, as i saiid theres nothing linking the compresor electric with the internal stat, there are presure switches inalong side compressor are these knocking compressor on/off, i was there fitting a new contacter which had burnt up my concerns being it has never switched off can any one advise please?
    11,025
    Re: electronic controller inside
    A little more description of the unit may help.
    What sort of split is it?
    Feb 2008
    manchester
    80
    if its a pump down system which it sounds like. I would suggest you look at the pressure switch sounds like its not knocking off hence contactor burnt out
    Apr 2009
    israel
    778
    HI it sounds like a pump down unit with low pressure control that cuts the compressor out.
    the thermostat controles the liquid solonoied.
    if your contactor burned out check contacts make sure no loose ones
    and verify amperage fits the load
    Jun 2007
    South Africa
    66
    120
    Sounds like the solenoid valve is closing by the controller, but the LP control is not properly set. Maybe compressor is running in a vacuum when in pumpdown.
    What is the suction pressure when the controller shows 1 deg. C?
    I am not always right, but I'm never wrong!
  1. Carrier Transicold Container Problem
    By Shamel in forum Transport
    Last Post: 23-01-2012, 11:23 PM
  2. LAE LEC3 TORDC electronic controller
    By Rickyjb64 in forum Trouble Shooting
    Last Post: 15-03-2009, 09:12 PM
  3. Electronic controller probes wired wrong
    By Electrocoolman in forum Trouble Shooting
    Last Post: 12-11-2007, 06:39 PM
  4. Electronic Controller Suggestions
    By Electrocoolman in forum Electrical
    Last Post: 10-11-2006, 03:39 PM
  5. Help with new electronic refrigerator controller !
    By EngiGal in forum New Technologies
    Last Post: 08-04-2006, 07:39 PM
