Results 1 to 9 of 9
12-08-2009, 10:10 PM #1
Samsung RL36 Ice build up in freezer
Gents,
I have a Samsung RL36 EBNS (Upright no-frost fridge-freezer) which is building up ice from the bottom up in the frezer compartment.
On ocassion water is released from the freezer compartment, but even after this happens a significant amount of ice will still be left in the bottom of the freezer.
What has possibly failed?
13-08-2009, 06:56 AM #2
Re: Samsung RL36 Ice build up in freezer
Dear Check for deforst Controller assembly.
Amit Saxena
13-08-2009, 06:49 PM #3
most likely a blocked drain. Turn off appliance, open doors, allow to defrost completely for 24-48 hrs. Put towels down to absorb melt water
14-08-2009, 09:08 PM #4
17-08-2009, 04:53 PM #5
17-08-2009, 07:57 PM #6
The drain hole is behind the 2 covers in the rear of the freezer. You have to move the evaporator assembly forward to reveal the hole
17-08-2009, 08:52 PM #7
17-08-2009, 09:18 PM #8
push a thin screwdriver into the slots to release the cover - its quite a tight fit
12-09-2009, 08:10 AM #9
Thanks again happy, problem solved.
An exceptionally long defrost would have also been enogh, have to give it a long enough time to make sure the drain also defrosts (last thing to do so) and obviously out of sight.
Regards,
Samsung RS21DCNS fridge freezer problem - please help!
By Jo G in forum DomesticReplies: 8Last Post: 08-08-2009, 05:48 PM
