Thread: TXV query
11-08-2009, 06:45 AM #1
TXV query
Dear All,
I have two identical system, the only diffenece i am finding is the TXV, as
Following are the observations,
1. The Suction temp. and pressure are higher as
System #1 System #2
20°C 28°C
2. The Eva. temperature is also on the high side as
System #1 System #2
3°C 10°C
Rest all parameters are same in both the systems
Can you suggest what all possibilities are there?
Amit Saxena
11-08-2009, 06:56 AM #2
Re: TXV query
Very likely there is less airflow through the condenser in system #2.
What are the entering and leaving air temps on both systems?Last edited by Gary; 11-08-2009 at 07:02 AM.
11-08-2009, 07:21 AM #3
Re: TXV query
Dear Mr Gary,
The entering and leaving air temps are as
System #1 System #2
Air In 42°C 42.1°C
Air Out 49.5°C 51.2°C
Amit
11-08-2009, 09:50 AM #4
Re: TXV query
is the heat load a bit lower in one room?
climatemaster geothermal heat pump query
By jackson in forum Heat PumpsReplies: 42Last Post: 14-01-2010, 08:52 PM -
Candy CIC324AK - Fridge Operating Query
By happyheth in forum DomesticReplies: 1Last Post: 30-12-2008, 09:06 PM -
Component balancing & cross plots query.
By refca in forum FundamentalsReplies: 0Last Post: 21-11-2007, 12:49 PM -
Foster query
By eam1956 in forum CommercialReplies: 4Last Post: 23-01-2006, 10:37 PM -
Capacitor query
By Coolie in forum Trouble ShootingReplies: 14Last Post: 05-11-2004, 07:35 AM
