    mhusens's Avatar
    mhusens Guest
    Gram Fridge Iced-up
    Help!
    I have an old Gram fridge [very reliable upto now].
    Recently, over the last 12months, ice forms on the back of the inside wall of the fridge. The ice is about 0.5cms thick now & covering almost 80% of the height of the internal rear wall.
    We have totally defrosted & cleaned the fridge both inside & out in January 2009 & also last week. Within 2days ice had formed again inside the fridge.
    We have tried turning the Temerature down but to no avail, though it appears that the thermostat is working since the motor stops if it is turned right down.
    Previously, the Thermostat was set at about 2 o'clock position without any ice forming but now it is turned down to about 11 o'clock position but the ice has not de-frosted. There is no apparent damage to the door seals either.
    Your help & advice will be much appreciated.
    Thanking you in anticipation.
    Oct 2004
    Scotland
    1,454
    21
    Re: Gram Fridge Iced-up
    Is there a fan on the inside like a K400?
    Sounds like the stat is goosed.
    Chillin
    and go get a cuppa
    mhusens's Avatar
    mhusens Guest
    Quote Originally Posted by chillin out View Post
    Chillin
    Thanks for your response.
    No - there is no fan inside the fridge.
    Also, what should be the right temperature at the Top & Bottom shelve of the fridge ? The fridge(only) is about 5ft tall.
    Sep 2008
    india
    10
    as you said that compressor is cutting off when thermostat position in made towards less cool.
    This fridge might have some timer or microprocessor to autodefrost which have gone faulty
    needs to check it and replace it
  1. Hotpoint Mistral Plus - Fridge Freezer
    By cozzie121 in forum Domestic
    Last Post: 19-09-2010, 08:45 AM
  2. Replies: 26
    Last Post: 09-03-2009, 11:04 AM
  3. Gram Fridge Icing Up
    By cgarrad in forum Commercial
    Last Post: 19-09-2008, 11:45 AM
  4. Back wall of fridge has iced up?
    By rumpelstiltskin in forum Domestic
    Last Post: 04-12-2007, 08:23 PM
  5. is my fridge working properly?
    By vincec in forum Trouble Shooting
    Last Post: 15-01-2002, 09:55 PM
