09-08-2009, 01:12 AM #1
Frick screw compressor 193L code S3
Hello
We are currently having problems with a frick screw compressor that is getting stuck in the 100% loaded position and when we turn it off it takes a very long time for it to get back to 0%, most of the time it needs assistance with gas pressure against the unload piston. We are going to recondition the compressor but need to get a tear down manual. we would appreciate any help given
09-08-2009, 01:24 PM #2
Re: Frick screw compressor 193L code S3
send it to glen at transcomp adelaide,
22-08-2009, 03:23 AM #3
Hi Mtsivis,
I have encountered the same problem several times,
the O-Ring on the piston rim expanded gets the piston stuck, so it is not necessary to dismantle the whole compressor, you need some special tools to do so,
give me your email adress, I can offer some information to you.
20-03-2010, 02:22 AM #4
The unloader spring could be broken or the valve guides may have extreme wear causing the slide valve to bind in the housing.
Frick screw compressor SGC3515 overhaul manual
By cjlee74 in forum IndustrialReplies: 10Last Post: 13-10-2010, 08:49 AM -
problem with volume on frick screw compressor
By samlee12 in forum IndustrialReplies: 4Last Post: 29-10-2009, 06:06 AM -
problem with frick screw volume
By samlee12 in forum Industrial CompressorsReplies: 9Last Post: 20-06-2009, 02:46 PM -
Frick screw manuals?
By JOHNO16 in forum Industrial CompressorsReplies: 1Last Post: 04-04-2009, 10:30 PM -
Frick screw paper
By RANGER1 in forum Industrial CompressorsReplies: 5Last Post: 08-03-2009, 08:45 PM
