Results 1 to 2 of 2
06-08-2009, 11:12 AM #1
McQuay ALS F XE273.2 990Kw, highest return temp?
Hi Gents
Anyone know the McQuay maximum return water temp for these chillers? McQuay ALS F XE273.2. 990Kw cooling capacity.
I have increased plant supply water to 14*C with a return of 17*C. I have been told it can handel 20*C return water because of compressor liquid injection. Is this correct or am i getting duff info?
Talking to Mcquay tech line is like pulling teeth and getting conflicting stories.
I have converted a data centre to supply air control and have saved 20% on chiller loading, plant water has increased 4K to double the free cooling operational time. I will publish my findings later on.
Cheers guys
Wombat
07-08-2009, 10:59 AM #2
Re: McQuay ALS F XE273.2 990Kw, highest return temp?
here's a chart of my savings
Best place for return air sensors, in the room or ceiling void?
By back2space in forum Air ConditioningReplies: 27Last Post: 06-07-2009, 06:21 AM -
how to determine air return temperature
By firmanardha in forum Air ConditioningReplies: 6Last Post: 31-01-2009, 03:34 AM -
Mcquay water source heat pump
By bernie in forum Air ConditioningReplies: 2Last Post: 10-02-2003, 01:53 AM
