    nicholaslsa's Avatar
    nicholaslsa Guest
    Is R22 - Chlorodifluoromethane corrosive?
    Hi guys,
    I'm new in RE, please help me out on this matter.
    I've a problem in this refrigerant gas R22, a leak in the system as cause some paint to be "eaten up".
    I'll like to know if R22 is corrosive? As I could not find any infomation of it on the net.
    Feb 2008
    adelaide sth.oz
    1,015
    Re: Is R22 - Chlorodifluoromethane corrosive?
    probably system oil reacting with paint
    11,024
    Extreme temperature difference could have damaged paint.
    Try searching the web again, there is a wealth of data sheets out there.
    Aug 2007
    Sydney
    52
    1,083
    23
    Hi Nicholasla
    Welcome to RE. R22 becomes acidic when exposed to moisture or over heating, the oil as mentioned above.
    Feb 2008
    adelaide sth.oz
    1,015
    use a better quality paint applied as per instructions,the only thing i know about 22 being corrosive is that it tends to scour the pipework due to velocity i think.
    can anybody enlighten me on this autoduh has kicked in
    Mar 2009
    U.S.A.
    320
    All the HCFC and CFC refrigerants are solvents and most will dilute oil-based paints...and many familiar solvents were subject to the same limitations as refrigerants in consequence of the Montreal Protocol.
    The original dry cleaning fluids are chemically similar to most refrigerants: This from Wikipedia:
    Before they became strictly regulated, the general public often encountered haloalkanes as paint and cleaning solvents such as trichloroethane (1,1,1-trichloroethane) and carbon tetrachloride (tetrachloromethane), pesticides like 1,2-dibromoethane (EDB, ethylene dibromide), and refrigerants like *****-22 (duPont trademark for chlorodifluoromethane). Some haloalkanes are still widely used for industrial cleaning, such as methylene chloride (dichloromethane), and as refrigerants, such as R-134a (1,1,1,2-tetrafluoroethane).
    Haloalkenes have also been used as solvents, including perchloroethylene (Perc, tetrachloroethene), widespread in dry cleaning, and trichloroethylene (TCE, 1,1,2-trichloroethene). Other haloalkenes have been chemical building blocks of plastics such as polyvinyl chloride ("vinyl" or PVC, polymerized chloroethene) and Teflon (duPont trademark for polymerized tetrafluoroethene, PTFE).
    So be careful what you use for a cleaner around refrigerants....Besides the carcinogenics, most of these are Central Nervous System depressants (and there's more fun ways to kill brain cells) and a few are hallucinogenic.
  1. water spray cooling
    Last Post: 11-09-2010, 08:21 AM
