Results 1 to 8 of 8
Thread: Insertion probe
02-09-2004, 06:22 AM #1
Insertion probe
We need to purchase pressure testing insertion probes (to insert through binder points on chilled water circuits) Any body in the UK know of a supplier, Have tried lots of web sites but had no luck
Jasper
02-09-2004, 07:30 AM #2
Re: Insertion probe
D&W, HRP, Control center all can supply Comark temprature monitoring equipment. Try www.comarkltd.com
it's only a fridge, fix it. ;)
02-09-2004, 07:33 AM #3
Re: Insertion probe
It's Pressure i need to measure, Looked on comarks site but can't find one
02-09-2004, 12:21 PM #4
Re: Insertion probe
Hi Jasper.
Any pressure tranceducer will do depends on what kind of signal you need.
If its in water, make sure it made of SS.
Chemi
02-09-2004, 01:55 PM #5
Re: Insertion probe
If you are in the UK, try these:
http://www.test-plugs.com/
I presume that you are using whatever has replaced the mercury manometer these days?
In the bad old days I used to use a manometer that would connect to the system through a couple of ordinary Binder points. Instead of having a screw thread, the insertion probe had a small nipple that you put your plastic tubes onto.
________
vaporizer manufacturerLast edited by Argus; 07-02-2011 at 09:09 AM.
02-09-2004, 04:01 PM #6
Re: Insertion probe
Thanks Argus
Excellent company, came up with the goods straight away
Jasper
02-09-2004, 05:16 PM #7
Re: Insertion probe
Glad you got what you wanted.
A tip...... if you are using Binders to test pressure, try to keep the probe tip out of the water flow because you'll pick up some velocity pressure on high volume systems that will distort your readings a little.
________
jugalettesLast edited by Argus; 07-02-2011 at 09:09 AM.
02-09-2004, 09:35 PM #8
Re: Insertion probe
BISRIA (BSRIA, can't remember for sure) sell & hire a lot of very useful stuff, and can probably help you out if you still need it. They're in Bracknell, but I don't have the no. to hand, sorry.
Temperature probe identification
By ecclesk in forum Trouble ShootingReplies: 14Last Post: 01-09-2005, 07:41 PM -
contact service probe
By Morph in forum Tools and CalculatorsReplies: 2Last Post: 09-04-2005, 08:22 PM
