01-08-2009, 07:26 PM #1
frigidaire comp running but not cooling
hi guys,
i have a frigidaire fridge/freezer. model number FRH 223.
my problem is the compressor is running but it doesnt seem to be as cold as it should be. i can set the thermostat as low as number 3, and it seems the compressor would just run forever.
discharge pipe on comp seems to be pretty hot, suction seem quite cool.
although it sounds like its short of gas i cant see any signs of a leak.
also, the fridge isnt fan assisted.
cheers in advance.
01-08-2009, 08:58 PM #2
Re: frigidaire comp running but not cooling
Just looked to your first post where some tried to help you with your Daikin BSbox back in 2008.
You never replied to the help which was offered by the members.
You never came back to give information how you solved the problem to help others.
Now I read your second post and this one is even more head scratching than the first one: if you're an AC engineer (and a long time member of this site), then you should know that you first have to do proper measurements on every refrigeration systems and diagnose it.
I can't help, but I have a strong feeling you only come here when you are in troubles asking for very basic stuff.
If you're qualified, you should have diagnose your fridge much further before asking your questions here.
Sorry, I couldn't resist.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
01-08-2009, 10:00 PM #3
Well thanks for that helpful post, I wasn't aware that I was supposed to come back and give a complete rundown of how I got it fixed. If anyone would like to HELP with the information I have provided, it would be much appreciated. I'll make sure I let you know if your info was useful
02-08-2009, 09:38 AM #4
Sorry but i have to agree with Peter.
If someone is kind enough to try and help you with your problem the least you can do is update the thread this way if anyone ever has the same problem as you and they do a search on the site they will find your thread and how to fix it.
Are you a refrigeration engineer? If so then the information you have provided is not enough for anyone to diagnose properly.
Are the coils clean? What are your pressures/temps? What amps is the compressor pulling compared to the nameplate? Superheat and Subcooling are few you need to come back with.The difference between genius and stupidity is that genius has its limits.
Marc
Some information on the aplication of suction gas/liquid line heat exchangers
By SteinarN in forum FundamentalsReplies: 5Last Post: 14-09-2009, 07:33 AM -
Frigidaire RL6003B not cooling
By antonhoward in forum DomesticReplies: 1Last Post: 12-06-2009, 04:21 PM -
Third comp change in three years, why?
By expat in forum CommercialReplies: 44Last Post: 16-10-2008, 03:48 PM -
cooling &freezing comp.
By afeef in forum Industrial CompressorsReplies: 25Last Post: 15-12-2006, 09:29 PM
