Thread: Faster Cooling
    Jul 2009
    11
    Faster Cooling
    If an evaporator has more CFM, does it mean that it is going to cool faster compared with another evaporator of the same characteristics with less CFM??
    Jul 2009
    11
    Re: Faster Cooling
    more CFM means more efficiency??
    Jun 2008
    Philippine
    52
    12
    Talking Re: Faster Cooling
    Depending on which type of cabinet the evap. fan is installed. In an open showcase, cfm is less so that cold will not be wasted throwing it outside the unit. In an enclosed type like cold boxes, it need a strong fan so that air will forced to moved around the close space especially in freezer where cold air is dense....
    getzzz.....
  1. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  2. Energy saving Glycol filled dry cooler circuits
    By Jasper in forum Technical Discussions
    Last Post: 19-06-2008, 02:18 PM
  3. Compressor loading, cooling, and range of operation.
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
Tags for this Thread
