Thread: Drier sizing
29-07-2009, 05:47 PM #1
Drier sizing
I am trying to figure out how to properly size a filter drier for a refrigerations system. I am looking to know how much desiccant is needed for several refrigerators that use small charges, 3 to 12 ounces R134a. Is there any easy way to figure out how much dessicant is actually needed for these systems? Thanks
29-07-2009, 07:36 PM #2
Re: Drier sizing
The manufacturer mostly states in his manuals for what capacity its filters are designed.
If you had a very good vacuum, then the smallest one will do the job perfect.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
30-07-2009, 05:31 AM #3
Re: Drier sizing
I agree with Peter 1, replace what was fitted originally, any thing bigger will act as a receiver and starve system and create issues in the off cycle, as in flooding evap., and create problems.
Capillary tube sizing
By Sledge in forum RefrigerantsReplies: 7Last Post: 16-11-2010, 11:44 PM -
suction line drier.
By Joeheath in forum Air ConditioningReplies: 5Last Post: 10-04-2008, 08:59 PM -
Sizing for Australia
By dogma in forum FundamentalsReplies: 5Last Post: 17-03-2006, 10:05 AM -
Shelf life of an uncapped dessicant drier.
By eberg in forum Air ConditioningReplies: 2Last Post: 22-08-2001, 01:22 PM -
Drier Position
By subzero*psia in forum CommercialReplies: 8Last Post: 23-07-2001, 10:28 PM
