    Mar 2007
    UAE
    43
    78
    Smile Dead load & live load for PU Panels
    Dear all,
    could anybody help me regarding this?
    I have to submit the following details to my consultant regarding construction of cold rooms with PU panels:
    • Dead Load
    • Live load
    • shear stress
    • deflection due to bending.
    The cold room is constructed with the following details:
    • Internal Dimensions: 4.89x1.49x2.45 m (LxwxHt)
    • Wall & Roof Panels :100 mm thk PU panels with 0.7 mm PVC plastisol cladding
    • Floor Panel :62 mm PU floor insulation including 50 mm thk PU panel ,12mm thk WBP plywood & 2mm thk SS chequerd plate.
    • Room temperature : 4 deg C
    • Foam density : 40 kg/m3
    I have to prove to the consultant that the permissible load for the floor panel is 4000N/rubber wheel at a surface of >4 cm2
    Kindly support me to prove.
    Advice me with your valuable statements & some useful links also.
    Thanks & Regards
    TJK2007
    Attached Files Attached Files
    Oct 2003
    5,630
    34
    Re: Dead load & live load for PU Panels
    Only the manufacturer of the panels can give you those via tests they've done unless it's a concrete floor.
    Feb 2008
    adelaide sth.oz
    1,015
    i wouldnt be using wood especially that thickness for a floor
    Oct 2003
    5,630
    34
    All the upper layer of the panels we use for floors is made of wood (panels with phenol glassfiber layer)
    How otherwise you could spread the load to the PU when entering with a reachtruck.
    Pointload of those we use (Isocab , Thyssen Krupp or Isobar) is 200kg/wheel (pointload) or 800 kg on 4 rubber wheels for a reinforced floor (= 15 mm wood)
    Feb 2008
    adelaide sth.oz
    1,015
    concrete type 15 mm sheeting has balls compared to wood that can break down with contnual exposure to moisture and can be covered in tin etc if job permits for ease of cleaning etc
    India
    688
    With such a small cold room, I wonder how the MHE can go in with 4 wheels. We use 125mm Thk floor panels with 12mm Ply wood & Chq Steel ( ss 304) for hand pallet truck movement & have seen no problems whatsoever even at -40 deg C
  1. bubbles on insulated panels by start-up
    By klaverlover in forum Trouble Shooting
    Last Post: 05-09-2008, 06:57 AM
  2. Compressor loading, cooling, and range of operation.
  3. PUF panels Vs PIR panels
    By smpsmp45 in forum NH3
    Last Post: 03-09-2007, 01:34 PM
  4. Manufacturing of PU PANELS
    By napter38 in forum Industrial
    Last Post: 21-10-2006, 09:22 AM
  5. AKV versus higher load
    By Peter_1 in forum Industrial
    Last Post: 18-04-2004, 11:05 AM
