Results 51 to 52 of 52
Thread: Helium for leak detection
07-03-2005, 09:48 PM #51
Re: Helium for leak detection
What about PED regulations which states much higher testing pressures (+/- 25 bars on high side in most occasions)
08-03-2005, 01:53 PM #52
PED = Design and Manufacture
Proof Test with Nitrogen or Argon (cheap and no environmental issues)
Leak Test at max operating pressure (limit pressure al la PED) with helium as it gives a quantifiable result if done in a chamber.
PSSR (UK) = Operation and Maintenace
Leak Test with helium and portable mass spectrometer (£16K) again gives a quantifiable result if elak is above background levels (10e-6 m.bar.lt.sec-1).
Washing Up liquid = corrosive salts and water will fill small porosities under capilary action and give false results but thats in the molecular leak rate zone.
Nitrogen Under water = corrosion risk and water will fill small porosities under capilary action and give false results but thats in the molecular leak rate zone.
Snoop or leak Detection Fluid = Not corrosive and viscious so pretty relaible for laminar leaks.
Ultrasonic = Excellent in plant rooms not good for low pressure slow leaks and won't pick up oil signature from temperature/vibration activated leaks. No quantifibale display!
Capacitive hand helds pick up every thing from cleaning solvents to bad breath but give users 'confidence' frequent 'ghost leaks' in plant rooms. No quantifibale display!
Beta source detectors relaible but radiation hazard means hassels at end of the warranty period. Gives ppm and mass per year.
IR Sensors good but bulky usually wall mounted and access by tubes making it slow to respond. Displays in ppm not mass per year.
New HFC legislation
This will mandate leak detection hand held for inspection.
Just the rantings of a few years trying to find Nirvana and missing it.....Derek
12VDC CO2 and Helium compressors??
By permafrost in forum TransportReplies: 2Last Post: 21-08-2006, 12:06 AM -
Law and Leak detection
By Bakerbj in forum FundamentalsReplies: 6Last Post: 21-03-2006, 10:39 PM -
Cost effective Freezer/Cooler Fire Detection
By Marvin in forum New TechnologiesReplies: 6Last Post: 14-12-2004, 09:20 PM -
Gas detection
By Mark in forum Supermarket RefrigerationReplies: 27Last Post: 08-08-2004, 07:04 PM -
Helium
By Mike Hopkins in forum RefrigerantsReplies: 3Last Post: 26-04-2002, 01:40 AM
