Results 1 to 1 of 1
28-07-2009, 08:22 AM #1
help! Israeli duct syst duct restricter motor
10kw old ducted spit system indoor unit in attic, feeding severeal rooms duct and return air ... but this system has little motors on 8 inch outlet air duct connecters with thin wires going back to an electronics box on the internal unit. I assume these are electoniically con trolled dampers. The name on the unit is Tadmor ezm400.
Please can anyone give me an overview how the air restricing system works, or if I can remove the autorestricting duct couplers without upsetting the system. The problem is with 2 of the rooms, one is freexing (and has a thermostat in the room) the other is warm (and doesnt have a thermostat in the room) I think the motor/electronics has failed with the cold room damper fully open and the warm room closed.
help with testing 3 phase comp
By mat in forum FundamentalsReplies: 7Last Post: 19-01-2007, 09:03 AM -
locked rotor amps (LRA)
By vinod in forum Technical DiscussionsReplies: 16Last Post: 09-09-2006, 12:50 AM -
current draw on condenser fan motor
By dan wong in forum Trouble ShootingReplies: 15Last Post: 25-05-2001, 06:12 AM
