Results 1 to 2 of 2
27-07-2009, 08:53 PM #1
Toshiba Super Heat Recovery Units
Just wondered if anyone having similar problems. About 6 weeks ago had problem with condenser fan fault stopping system, changed motor and IPDU as recommended by Tosh tech. Problem has repeated on same unit, with same solution recommended by Tosh, IPDU was supposed to be upgraded type and no failures up to now? Not well up on DC motor testing. With IPDU totally disconnected from system but still connected to motor, drag is felt if blade moved but this disappears if one of the motor leads is disconnected. Original IPDU generated same drag but different lead released drag? Good IPDU generates no drag.
Just been told that a new IPDU not available until 3rd week in August, customer not pleased. Sorry about going on a bit.
28-07-2009, 04:58 PM #2
Re: Toshiba Super Heat Recovery Units
had a site where i replaced 6 of these in as many months,tosh as you said have upgraded the IPDU PCB and offered them to our company under warranty,it was also recommended that additional heat seal be used when fitting the IPDU PCB
Paul
"KEEP IT COOL"
Super heat
By shills33 in forum FundamentalsReplies: 6Last Post: 21-07-2009, 01:06 PM -
Toshiba Super Heat Recovery system
By billywizz in forum Air ConditioningReplies: 6Last Post: 26-06-2009, 09:21 PM -
heat pipe recovery issue
By Lc_shi in forum New TechnologiesReplies: 8Last Post: 12-03-2009, 10:39 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
heat recovery wheel
By joel in forum Air ConditioningReplies: 2Last Post: 12-10-2007, 01:45 AM
