Thread: Aluminum welding - Evaporator
26-07-2009, 03:43 PM #1
hi everyone i am looking for easy and good way to weld evaporators and pipes in refrigerators.
27-07-2009, 01:12 PM #2
Re: Aluminum welding - Evaporator
Hi there, if it's a wetplate evap (like in a domestic fridge) then there's a resin available off the shelf which you heat up and splodge on, works well if it's clean and accessible, eg knife wounds from diy defrosts. as for welding coils, you'll need the correct rods, i recommend gas welding but you'll need practice as aluminium doesn't turn red before dissolving into a blob, and coils are often tissue thin. many coils are copper under a aluminium fin affair, so you can just burn it off to gain access to the leak, every one's different so it's hard to be specific, good luck
Superheat and Subcooling
EVAPORATOR leaked
By James priyono in forum Air ConditioningReplies: 4Last Post: 23-05-2009, 10:19 AM -
soldering aluminum evaporator
By stegmo2 in forum Supermarket RefrigerationReplies: 13Last Post: 12-05-2008, 07:46 AM -
Absortpion Refrigeration - Evaporator Basics
By knudo in forum FundamentalsReplies: 4Last Post: 28-08-2007, 08:03 AM -
What is the best location for a evaporator fan?
By Jasno999 in forum FundamentalsReplies: 3Last Post: 21-02-2007, 12:34 AM
