Thread: return lines
27-07-2009, 07:55 AM #1
return lines
give me the definition of a return line, I am familair with liguid, suction and hot gas lines on a nh3 system.
27-07-2009, 10:19 AM #2
Re: return lines
Can you please expand the term or its context ?
27-07-2009, 01:23 PM #3
Re: return lines
You have to provide more context on the actual pipe you are describing. Is it for defrost or something else. The terminology used in this business can be confusing because there is very little agreement on what something should be called.
28-07-2009, 08:00 AM #4
Re: return lines
GIVe it to me!
Best place for return air sensors, in the room or ceiling void?
By back2space in forum Air ConditioningReplies: 27Last Post: 06-07-2009, 06:21 AM -
LP/HP Connector Lines
By jwasir in forum FundamentalsReplies: 4Last Post: 18-02-2009, 06:06 AM -
What is return gas temperature?
By david2008 in forum Technical SpeculationsReplies: 8Last Post: 09-07-2008, 12:47 AM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM -
return air
By subzero*psia in forum Air ConditioningReplies: 1Last Post: 12-07-2001, 04:02 PM
