    nostalgia's Avatar
    nostalgia Guest
    Urgent: absorption chiller
    Could you please give any information or references about these points:
    1. how does the quality of the refrigerant effect the absorption chiller?
    2. how does the quality of the steam ,which used to heat the absorbent, effect the absorption chiller?
    Br
    Mar 2009
    U.S.A.
    320
    Re: Urgent: absorption chiller
    Absorper pair is?
    Liquid ammonia carryover to an absorber causes high-high heat rejection requirement at the absorber (extra cooling required) and rise in T-evap.
    Water in your steam supply will cause the regenerator temperature to want to rise; though this a little hard to detect at low water contents....
    Remainder depends on the exchange between Low and High Side.
    Apr 2008
    8
    What type of machine are you talking about. Is your refrigerant water? is your absorbant lithium bromide?
    nostalgia's Avatar
    nostalgia Guest
    Quote Originally Posted by weatherman View Post
    YES , its water/LiBr
    11,025
    Quality is everything with refrigeration.
    Pray tell, why is this question so urgent ?
    Apr 2008
    8
    Quote Originally Posted by nostalgia View Post
    If the machine has been running at low load for a long time the water may be contaminated with lith/brom this needs to be reconstituted. You may have to add some octy alchol to the water,The steam or hot water needs to be at the machine design temp and the condenser/absorber water needs also to be at design to ensure correct operation. Take samples of refrigerant and lithd/brom and check consentrations
  1. Ice rink with Absorption chiller
    By mjsnow in forum Technical Speculations
    Last Post: 21-09-2009, 07:08 AM
  2. Repeated tubes failure in absorption chiller unit
    By nostalgia in forum Trouble Shooting
    Last Post: 17-08-2009, 06:35 AM
  3. Absorption Chiller VS Mech. Chiller
    By Intern in forum Industrial
    Last Post: 30-05-2009, 08:31 AM
  4. Absorption chiller price estimation
    By formy in forum Industrial
    Last Post: 25-05-2009, 03:28 PM
  5. centrifugal chiller VS absorption chiller
    By Masdede in forum Air Conditioning
    Last Post: 01-03-2009, 12:28 PM
