Results 1 to 13 of 13
    Katy's Avatar
    Katy Guest
    Coca Cola Display Fridge Help!!
    I have a single door Coca Cola Display fridge which I inherited when I bought a new premisis.
    When i originally looked around it was working and since moving into the premisis it isn't working.
    We have tried to put a new 13amp fuse in the plug and it switched on for about a second and then blew the fuse.
    Is there anything you can suggest or does it need an engineer?
    If it needs an engineer do you know any company that services them?
    Thank you
    Apr 2001
    79
    5,071
    35
    Re: Coca Cola Display Fridge Help!!
    Was it a time delay type fuse?
    Jun 2005
    Stoke on Trent
    588
    Is it possible that the mains lead has been pulled or damaged in some way, dont overlook the obvious first.
    Feb 2008
    adelaide sth.oz
    1,015
    as andy suggested,if its a coke badged/branded fridge and everything appears ok.in south australia coke are responsible for the repairs as they own the cabinet.
    might pay to check up on this and have it repaired for free.
    Oct 2006
    1,843
    Hi Gary.
    In the UK domestic plugs are standard and take the same size fuse dimension wise but the amp rateings are different up to a maximum of 13 amp.
    So all plugs are standard and so are the fuses.
    Quote Originally Posted by lowcool View Post
    In the UK the fridge is under licence to coke for a period of time and then becomes the property of the owner or the owner can buy the fridge out right from new at a discounted rate and is only suposed to stock it with coke products.
    As the others have posted though I would start with the basics and check the power cable from plug to fridge, check for it being trapped or pulled.
    If the lead is ok the somthing on the system electricaly is faulty, such as the comp, fan motors, trim heaters or somthing else like that.
    If it is not the lead it will need someone to look at it who knows what they are doing.
    Cheers taz.
    scotland
    756
    it is quite obvious katy does not have electrical expierience or knowledge so best for all that he/she gets the experts in!
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by taz24 View Post
    Hi Gary.
    Ours are, too. But they come in fast blow and slow blow versions. Anything with a motor needs slow blow fuses because of the starting current.
    Oct 2006
    1,843
    Not in the UK.
    taz
    Feb 2008
    adelaide sth.oz
    1,015
    in oz we have breakers and fuses suited to the motor curve at start up,no more replacing them so often and cuts down on diagnosis time.many a time have come across fuses and breakers tripping for no reason
    v8dve's Avatar
    v8dve Guest
    Katy,
    Speak to Coca Cola at Milton Keynes to find out if it is their property and you might get it done for free, if not call out a local engineer.
    Brendon86's Avatar
    Brendon86 Guest
    To be honest I would call in the fridgy's It could be a number of problems. If you used the right type of fuse and it blew after a second it may be a compressor or fan motor but as i said it could be anything.
    Good luck
    india
    Smile Re: Coca Cola Display Fridge Help!!
    Dear Katy,
    First of all u should check the operating voltage of that coke visi cooler which is recomended by the manufacturer, if it is operating with 110 volts then u have to installed a step down voltage stabilizer which operates the supply voltage. if the the operating voltage is correct as per recomended and still that visi cooler is not working then u have to check the continuity of the main probe (leed) and three pin top of the visi cooler with the help of multimeter because in transportation the main probe may be tempered.
    mehtag ( Service Engineer Pepsi Visi coolers in India)
    Apr 2007
    371
    where abouts are you welling......?
  1. Chocolate display fridge
    By danpitcher in forum Commercial
    Last Post: 12-04-2009, 09:30 AM
  2. Display fridge
    By SUBCONTRACTOR in forum Commercial
    Last Post: 03-10-2008, 09:40 AM
  3. cold display unit with fridge in system!
    By andyuk10841 in forum Trouble Shooting
    Last Post: 20-05-2008, 01:02 AM
  4. Beverage cooler testing methods: coca cola vs. ISO
    By MrsFreeze in forum Commercial
    Last Post: 03-04-2007, 10:40 AM
  5. Replies: 8
    Last Post: 20-05-2006, 04:21 PM
Tags for this Thread
