    mgus's Avatar
    mgus Guest
    Refrigeration agent with temp above boiling point?
    Hello,
    Newbie and total novice here, so bear with me.
    My question is if there are any refrigerants - as in 407-C - with a release temperature (when compressed from gaseous phase back into liquid phase) above 100 degrees Celsius?
    regards,
    mgus
    Apr 2001
    79
    5,071
    35
    Re: Refrigeration agent with temp above boiling point?
    Your question makes no sense.
    Start here:
    http://www.refrigeration-engineer.co...ad.php?t=19701
    mgus's Avatar
    mgus Guest
    Thanks.
    3,853
    R718
    and its cheap too
    mgus's Avatar
    mgus Guest
    As I understand it, it depends on to what pressure you take the heated vapor - that way you can get either low heat or high heat (to a lesser degree of efficiency).
    My thoughts were about this product:
    www dot solarpst dot com
  1. Ultra low temp refrigeration
    By Nuklhed in forum Refrigeration Books
    Last Post: 25-03-2006, 03:05 PM
  2. sizing of low temp refrigeration cabinets
    By DALO in forum Technical Speculations
    Last Post: 15-01-2006, 08:31 PM
  3. Condensing temp in refrigeration
    By anup in forum Fundamentals
    Last Post: 02-10-2005, 11:18 AM
  4. Oil Migration - R22 medium temp refrigeration system
    By lurioda in forum Trouble Shooting
    Last Post: 09-03-2004, 03:38 PM
