Thread: Air Source components
22-07-2009, 09:53 AM #1
Hi folks.
We're getting our friendly local air con engineers to modify an air source heat pump. specifically, they are changing a heat exchanger. The one fitted is like a small black clyinder, two refridgerant pipes and two water.
Any idea where we can source similar? I'm just trying to do some of the running around so we are (nearly) organised.
thank you
Matt
12-09-2009, 01:29 AM #2
Re: Air Source components
Sounds challanging.
Why?
12-09-2009, 01:47 AM #3
try daikin
How to provide source of make-up air?
By toddreg in forum CommercialReplies: 5Last Post: 16-04-2009, 05:48 PM -
Air source heat pump modification
By rt29781 in forum Heat PumpsReplies: 4Last Post: 23-12-2008, 08:41 AM -
Ground source or air source heat pumps?
By Karl Hofmann in forum New TechnologiesReplies: 16Last Post: 20-08-2008, 05:23 PM -
About gas blend properties (how can high pressure components condense?)
By DaBit in forum FundamentalsReplies: 17Last Post: 11-02-2004, 02:23 AM
