    Jul 2009
    mexico
    7
    Testing pressure and checking for leaks
    I have a chigo 12000btu mini split ac unit which flashes e4 after running for about 30minutes. After looking at their site and reading the minimal information available for this unit on the web, I believe it has to be a pressure problem.
    My question is this: what tool would I need to check the pressure of this unit, and where would be a cheap place to grab one.
    It needs to be 410a/2. 54lbs
    Also what is the best way to check for leaks?
    Thank you and help and input would be greatly appreciated.
    Mar 2008
    55
    273
    Re: Testing pressure and checking for leaks
    You should have a refrigerant handling certificate before you attempt to do this .
    Transvestites are men who like to eat, drink, and be Mary.
    Feb 2001
    Doncaster, England
    199
    Hi philfridge
    In UK you do - but he's in Mexico
    Tony
    Jul 2009
    mexico
    7
    I installed the unit myself, and feel as if I'm capable enough as long as I have the correct tools. Also I have re-charged the my ac in my car without considering myself a mechanic. Anyhow would the gauges I used on my car be the same, or are they a different size?
    Oct 2003
    5,630
    34
    You need other hoses or adapters because your car is 1/4 SAE and R410a is 5/16 SAE.
  1. leak checking
    By captainleaky in forum Trouble Shooting
    Last Post: 20-06-2009, 07:31 PM
  2. pressure testing
    By bangoman in forum Air Conditioning
    Last Post: 11-11-2008, 12:43 PM
  3. Leak Testing Daikin K Series VRV
    By jedi in forum Trouble Shooting
    Last Post: 21-08-2008, 07:16 PM
  4. Intermittent Oil Pressure Failure
    By knkreb in forum Trouble Shooting
    Last Post: 02-04-2008, 11:18 PM
  5. Pressure testing
    By Chopper in forum Industrial
    Last Post: 24-10-2005, 06:40 PM
