Results 1 to 11 of 11
    Aug 2004
    Transparent heated windows
    I've been looking into ITO (Indium Tin Oxide) coated glass for a decorative lighting application, and discovered that it is commonly used for heating glass-fronted freezer cabinets, and this may be a possible cheap-ish, or at least off-the-shelf, source.
    However I've had no luck in finding what the typical resistivity of the coatings is for this application - if anyone can tell me the voltage & wattage rating of a panel of a specific size, I can work it out.
    Also, what sort of money do these heated glass panels cost (e.g. as replacements) in the UK ?
    I'd be grateful for any info or pointers to data, thanks.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Transparent heated windows
    Aug 2004
    Thanks - I've seen some of these places, but what I'm after is info on the characteristics of the ITO glass that's actually used in freezer cab doors, as these (replacement doors or from scrapped cabs) are a potential source of 'ready made' ITO panels for cheap low-volume/experimental use.
    Sep 2003
    ISRAEL
    72
    4,248
    You will have to search it with Google.
    I'm sure there is a lot of information out there.
    Nice web site. I intend to check it out later.
    Chemi
    Aug 2004
    Quote Originally Posted by chemi-cool
    Chemi
    I've spent at least 2 hours looking on the net and failed to find any concrete information on th epanels used for freezers. All I need is something like "panel x by y mm, rated z watts at 230V" to figure out if it would be suitable for what I want.
    Dec 2001
    nottingham
    96
    23
    http://www.sigmaaldrich.com/Area_of_...de_Slides.html
    Found this link on Google, it may be of some help
    Aug 2004
    Quote Originally Posted by Jasper
    These are optical slides for lab use - I'm trying to find the characteristics of the glass used for freezer doors.
    Sep 2003
    ISRAEL
    72
    4,248
    I dont think that any one will publish those details.
    Is it possible to measure existing glass coating?
    Get in touch with one of the manufacturers and try there.
    Chemi
    Aug 2004
    Chemi
    Why would anyone not publish the size and wattage of their panels ?
    Yes I could measure one if I had access to one, but I don't - I'm just trying to get an idea of the spec to see if it's worth investigating this avenue further....
    May 2004
    southern england
    69
    86
    it's only a fridge, fix it. ;)
    Sep 2003
    ISRAEL
    72
    4,248
    There should be demend for this kind of information and I think you are the first one.
    Chemi
  1. nasty Windows virus
    By chillin out in forum Computers & the Internet
    Last Post: 27-02-2006, 11:01 AM
