Thread: mitsu lossany
    Feb 2007
    SIDE OF THE ROAD
    262
    mitsu lossany
    hi
    i am looking to power and wire up a lossany hrv and was wondering, do i have to get seperate control for this or can i tap off an excisting mitsu controller belonging to a vrf system with a g50 central control ???
    rgrds phil
    Mar 2007
    Warwickshire UK
    723
    21
    Re: mitsu lossany
    Yes can control using G50 / AG150
    Make Mnet 30v dc wiring on daisy chain with any other indoor units.
    Make sure the Lossnay address is after all the indoor units.
    For example
    If you have indoor units 001 up to 045
    then make Lossney address 046 up to 050.
    When you program the G50 you can make each loosney a group & control the same as any other indoor unit & make any time clock shedule for each loosney that you feel appropriate.
    You also have the option to interlock so that when any indoor unit is turned on the lossney automatically comes on also.
    Feb 2007
    SIDE OF THE ROAD
    262
    Re: mitsu lossany
    thanks thermatech,
    so..i will connect the lossnay on the m net, and this will automatically picked up by the g50 once the addresses are correct, the only thing i wil have to do is edit the name of unit maybe???
    i just wanna get thing running on the same schedule as indoors thats it..
    rgrds phil
    Mar 2007
    Warwickshire UK
    723
    21
    Re: mitsu lossany
    Thats it
    Give the Lossnay an address the same as you would any indoor unit.
    Dial that address in for a group at the G50 the same as you would to set up any indoor unit at the G50.
    Give the Lossnay group the same time clock schedule you give to all the indoor unit groups.
    Feb 2007
    SIDE OF THE ROAD
    262
    Re: mitsu lossany
    thanks therma
  1. Mitsu a/c
    By sheao in forum Trouble Shooting
    Last Post: 20-08-2008, 11:22 PM
  2. mitsu heavy inds remote display
    By dirker in forum Heat Pumps
    Last Post: 08-04-2007, 10:54 PM
  3. Mitsu Heavy Industry
    By bobjob in forum Air Conditioning
    Last Post: 14-07-2005, 11:00 PM
  4. Mitsu
    By Abe in forum Air Conditioning
    Last Post: 05-01-2003, 02:19 PM
  5. Mitsu High Wall
    Last Post: 07-05-2002, 05:59 PM
