Results 1 to 50 of 53
Thread: The amazing Mr. Cap Tube
23-08-2004, 01:37 AM #1
Re: The amazing Mr. Cap Tube
Marc I have to admit that I don't have a clue as to what all your fancy foot work means as I know not about the SI system so I can't repond to that but please tell me what the hell do you mean by CARYOVER
23-08-2004, 04:02 AM #2
Rog:
A cap tube does have some load adjustability don’t you know, but nowhere near what a TXV can do, but as the ambient changes, the degree of sub cooling will change in an air-cooled condenser, and as a result, the bubble point and two phase length will change and although head pressure has an effect on flow rate, it’s the changing two-phase length that counters this action. Sub cooling the refrigerant has the greatest effect on flow rate. For my money the manufacturers’ design engineers have to go through many tests before establishing an optimum bore and length and it may change many times before they achieve the most efficient system. So I think I’ll stick with their values. You seem to believe that you know how to better improve a cap tube system; if that’s the case by all means do so and help the world conserve more energy through your advanced technology
23-08-2004, 04:21 PM #3
Carryover is the coexistance of liquid and vapor in an area that is subcooled or superheated. Specifically it refers to vapor bubbles carried over into the subcooled liquid line or liquid droplets carried over into the superheated suction line.
25-08-2004, 02:11 AM #4
Marc That's very cute!. .NOT! so why don't you take Aristotle"s advce? And get off the EGO TRIP you didn't say any thing that is not understood in ASHRAE literature wise guy! Geeezzz your such a Glippy Dork and that last paragraph was totally un called for and just shows what a putz you are!
25-08-2004, 03:40 PM #5
Originally Posted by Marc O'Brien
With the same load and higher ambient, a cap tube would indeed provide increased flow, but a rise in SST (saturated suction temperature) would probably indicate a compressor operating at a less efficient point on its capacity curve due to the higher condensing pressure, and possibly additional load from carryover of some excess liquid refrigerant to the crankcase.
Rog
26-08-2004, 01:08 AM #6
Rog
26-08-2004, 08:19 PM #7
The Daikin Super Inverter systems we sell compare indoor temperatures to outdoor temperatures and float indoor temperatures relative to outdoor temperatures.
They didn't mention this on the training course
27-08-2004, 01:19 AM #8
Marc “Acute semantic aphasia” back at you pal
You have to think about the explanation as well as the description of a
Phenomenon. Explanation often takes the form of a hypothesis. Therefore, whether or
Not people entertain hypotheses is a useful measure in describing the scientific
discovery processes. So in order to convince us of your entire BS, you have to consider and discriminate among several plausible alternative explanations. Therefore, the extent to which subjects critique other hypotheses or entertain alternative hypotheses can measure how broadly they search the hypothesis space and make up their own minds. Capish!!
28-08-2004, 01:56 AM #9
Originally Posted by Marc O'BrienOriginally Posted by Marc O'BrienOriginally Posted by frankOriginally Posted by Marc O'Brien
Hmmmm. After some of the above, Marc might want to consider a disclaimer of some sort, so as not to confuse the lads. Something at the end of his posts like:
“Notice: Many of the claims in this post are entirely fictional and are intended for purposes of entertainment only. Any similarity to actual systems and practices is purely coincidental.”
That ought to cover it!
Rog
25-08-2004, 11:25 PM #10
:Originally Posted by shogun7
cap tube pumps
By magnumman414 in forum CommercialReplies: 9Last Post: 27-08-2007, 07:32 PM -
oxidation scale in copper tube and fittings
By DeB in forum FundamentalsReplies: 8Last Post: 23-06-2006, 09:45 PM -
metric capillary tube
By tralex in forum FundamentalsReplies: 5Last Post: 21-02-2006, 06:57 AM -
Cap Tube Sizes
By Latte in forum FundamentalsReplies: 14Last Post: 27-04-2005, 08:16 AM -
Tube staggered/squared
By bersaga in forum FundamentalsReplies: 2Last Post: 05-01-2003, 11:56 PM
