Thread: tefcold fs1380
    Nov 2008
    wakefield
    74
    28
    tefcold fs1380
    Hi everybody,
    will the above display cabinet work ok without the small fan blowing on compressor.Have had to disconnect .
    thanks
    Somerset
    69
    4,698
    Re: tefcold fs1380
    Hi folco.
    I don't know the cabinet described.
    But it is logical to assume that the comp / system needs the fan.
    Therefore You could assume that it is necessary!
    Cheers Grizzly
    Jun 2005
    Stoke on Trent
    588
    Re: tefcold fs1380
    Yes it will work as long as it is not in an high ambient as a temporary measure, have a feel of the filter drier, you will soon know if it will work.
    Nov 2008
    wakefield
    74
    28
    Re: tefcold fs1380
    thanks guys
    Oct 2006
    Bucks, U.K.
    71
    604
    Re: tefcold fs1380
    New fan cheaper than new compressor!
    Nov 2008
    wakefield
    74
    28
    Re: tefcold fs1380
    new fan on way,you are right.
    Jan 2008
    north west
    42
    234
    Re: tefcold fs1380
    replace fan before you ruin a perfectly good comp. if its there it is there for a reason.
