16-07-2009, 02:11 PM #1
Bosch Fridge Freezer Control Panel Problem
Hello. Please can someone help/advise. I have a KGU3102/GB Fridge Freezer which has never given any problem. A short while ago the Control Panel stopped working (apparently). There is power to the panel housing unit, the on/off and door switches work, but the LED Temperature readout is not illuminated, and the compressor and other button controls on the "PC Board" unit do not work. A local engineer called and checked, advising that a replacement PC Board unit was required.
We agreed I could get a new one and fit it on receipt, as it just plugs in with two standard white terminal blocks. I have obtained a new PC Board, and have plugged in the two terminal blocks into the PC Board/Control Panel unit - but it does not work!
Please can someone advise what the likely fault is and how to repair it?
Thanks in advance.
Bork
25-08-2009, 01:02 AM #2
Sub Zero 550. Seperate fridge and freezer controls/thermostat/compressor. Fridge working fine. Freezer will run fine, go without issue for 1-2 day period. Temp getting very low
Thanks.
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 01:26 PM -
Frigidaire FRC150 FF - fridge not very cold freezer forming frost!!
By TriciaA in forum Trouble ShootingReplies: 3Last Post: 04-08-2009, 04:24 PM -
Domestic Fridge Freezer one compressor?
By SkyWalker in forum FundamentalsReplies: 9Last Post: 12-10-2008, 03:28 PM -
Bosch Electronic Fridge Freezer KGE3434GB/01
By tintagel_mouse in forum DomesticReplies: 0Last Post: 26-09-2008, 11:06 PM -
coolinf fan problem samsung rs21 dgrs fridge freezer
By bogtrotter in forum Trouble ShootingReplies: 6Last Post: 21-03-2008, 08:45 PM
