14-07-2009, 08:22 AM #1
Anyone having problems with GAMKO build quality?
I am.
I sold a 2-door and a 3-door bottle cooler (both sliding door ones) and had horrendous issues with them to the point where I had to give the customer two of the Interlevin ones.
Amazingly he's happier with the Interlevin ones as they are staying together better.
The main problems we had were with the structure of the units.
As you can see from this picture the cabinets is completely off-square
This caused sticking doors, water leaks, etc.
The manufacturers even replaced the unit and the replacement was worse than the first one.
Anyone else have this sort of trouble or am I alone?
If it was easy everyone would do it.
14-07-2009, 09:41 AM #2
Re: Anyone having problems with GAMKO build quality?
Do they have foot adjustment screws underneath them?
14-07-2009, 01:29 PM #3
these cabinets use polystyrene slab insulation and have no strength unlike most commercial cabinets that use a 2 part foam that is injected into the cabinet and expands and gives makes it rigid.
new one on me anyway
14-07-2009, 01:50 PM #4
if you had leveled the cabinet up with the feet or some timber you would of been fine
16-07-2009, 12:18 PM #5
just found out they are owned by foster refrigerator, that explains a lot!!!!!!!!!!!!!!!!
16-07-2009, 07:47 PM #6
Thats was just recently tho, foster havent YET messed about with the design of the cabinet.
I do all the service work for GAMKO AND Foster in scotland and iv never came across a situation were the door are not level.
Only real issue with gamko was the absolute rubbish controller they used too use but they solved that problem out
Compressor failure/ shut down due to Power Quality Problems
By protect in forum Trouble ShootingReplies: 2Last Post: 01-01-2011, 03:57 AM -
Suction pressure problems on TS units at low ambient temps
By nova in forum TransportReplies: 10Last Post: 18-03-2006, 07:35 PM -
Problems LG don't want you to know about
By Andy W in forum Air ConditioningReplies: 11Last Post: 16-02-2006, 04:52 PM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM
