Results 1 to 10 of 10
Thread: Add Refrigerant R407C
12-07-2009, 10:08 PM #1
Hi to everyone.
Can someone please tell me how to use a manifold gauge to add ***** R407C to a ductless split unit air conditioner?
12-07-2009, 10:12 PM #2
Re: Add Refrigerant R407C
No .
13-07-2009, 11:40 AM #3
Hi.
I see you are located in Cyprus,, if you are anywhere near Paphos let me know and i will be more than happy to come and do it for you,, it is not a job to be taken lightly tho, i really would not recommend trying it yourself if you don't know what you are doing,,
regards,
Lee
13-07-2009, 01:47 PM #4
what happened to nice guy brian ... but your answer was spot on
13-07-2009, 02:22 PM #5
Yes..
Contact your local quallified engineer and ask them to do it.
There is a reason they have not made a mechano refrigeration kit.... ITS NOT A TOY.
13-07-2009, 11:23 PM #6
14-07-2009, 06:10 PM #7
You must be charmed Brian.
Every time I try and be so brutal "the guys!" shoot me down for not being sympathetic!
Good answer all the same!
14-07-2009, 06:48 PM #8
OP
A Milk Bottle and some garden hose will C U right!
(Keep the Milk bottle pointing to Hell!)
He who dies with the most Toys, WINS!
19-07-2009, 09:50 PM #9
Finally I added the refrigerant R407C. Not so hard though he liquid side by using a 20 dollar manifold gauge.
Thanks for the help guys!
26-07-2009, 01:45 AM #10
They were giving you good advice, though.
Quite apart from the potential self damage you can do to yourself with this kind of DIY, there are other issues:
Why you would need to add refrigerant suggests a leak, which would need checking and repair, pressure test and, normally not a top-up but a new charge.
How much to add? Well there is another question....too much is bad, so is too little.
A DIY top-up probably means some air in the system too, now, so you can expect some difficulties with the system.
You may feel like you have save a chunk of money but I suspect it was wasted money as you most likely will still need a qualified engineer on site to fix the system up properly. Suggest you contact aircon rep tec for an early visit.
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
MHI FDCA400HKXRE4 Tech Info Please
By L.JT in forum Trouble ShootingReplies: 5Last Post: 23-08-2008, 11:00 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM
