Results 1 to 11 of 11
Thread: Williams Freezer
09-07-2009, 11:47 PM #1
Williams Freezer
Need some help please, I went to upright commerical freezer, needed re-gas, did not have time switched off, went back in 2 weeks, replaced dryer checked for any blockages as capillary, re-gased but when switched on, compressor (Embraco NJ2212GK R404) just getting hotter and hotter, checked capacitors ok, any idea's guys what this could be much appreciated thanks.
09-07-2009, 11:51 PM #2
10-07-2009, 09:53 AM #3
Re: Williams Freezer
Yes i fixed the leak it was the service valve, So i fitted new one thanks
10-07-2009, 01:07 PM #4
10-07-2009, 09:07 PM #5
hi fridge9
u have started wrong way u changed drier before u check the compressor or any thing else.
u have to prvide more info so u can have more help.
check the motor winding& amp draw.
and abour the service valve i thik some body else has came before u to this job
14-07-2009, 12:10 AM #6
Hi guys, I have changed the dryer, i have blown nitrogen around the sysem and through the capillary all clear, then put gas in R404 the compressor did not start it was just getting hotter and hotter, Checked windings all ok, i hope this helps thanks
14-07-2009, 12:37 AM #7
You're right about the compressor i just checked its a 34cc 1HP, much to big, as its only a single door, a 20cc would be big enough for that freezer, may be it is to big and its burnet itself out!
14-07-2009, 07:16 AM #8
If the compressor did not start but just got hotter and hotter then it is seized (locked rotor), it must be going out on the klixon then.
14-07-2009, 10:55 AM #9
Yes it was going out on the klixion, then after a while it was re-setting its self, what size compressor would you recomend for a 600Ltr single door freezer then, thanks for you're help.
14-07-2009, 01:23 PM #10
14-07-2009, 09:47 PM #11
Thanks Steve, for your advice, will have a look
Blast Freezer Within Freezer
By rickmor in forum Technical DiscussionsReplies: 4Last Post: 18-06-2009, 03:37 AM -
williams freezer
By park in forum CommercialReplies: 2Last Post: 30-05-2009, 03:17 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Freezer compressor running 20 Hours/day
By rickcw in forum DomesticReplies: 12Last Post: 08-03-2008, 11:50 PM -
Trolley freezer & blast freezer
By smpsmp45 in forum NH3Replies: 0Last Post: 25-08-2007, 07:29 AM
