Thread: ice cream machine
09-07-2009, 08:57 PM #1
ice cream machine
looking at an ice cream machine it had a new compressor fitted to it by another engineer but he never finished it. So i changed the drier, vacuumed and topped up with gas. The system was r12 but the new comp was r134a. I've used r409 gas.Now when ever its turned on there is no heat in the liquid line plus the discharge is'nt as warm as it should be, but the suction is freezing. It pulls the first few ice cream ok but is taking to long to prime after.Then when it is turned off the suction line loses it's freeze stright away then there is like a whistle sound like gas leaving the chamber. any thoughts??
ps mod's i put this in domestic by mistake sorry
09-07-2009, 09:14 PM #2
Re: ice cream machine
We can't see it from here and you have provided almost zero information.
TXV or cap tube?... temperatures?... pressures?
At this point if I had to take a wild guess I would say it is probably overcharged, but that's just a guess.
09-07-2009, 10:38 PM #3
10-07-2009, 08:50 PM #4
hi
metering device expansion or cap are too much different the orifice in f 12 too much wider then 134 so thats why ur suction freezes quick
u have to check expansion device&start from from here
check compressor capacity & make a good selectionfor ur tev
Carpigiani ice cream machine charging
By mr whippy in forum Technical DiscussionsReplies: 9Last Post: 31-01-2009, 02:30 PM -
ice cream machine
By jnyao in forum CommercialReplies: 20Last Post: 08-07-2007, 09:15 PM -
Elderly Ice cream machine.
By Onthecut in forum Trouble ShootingReplies: 12Last Post: 20-11-2005, 11:31 AM -
Cattabriga Ice Cream Machine
By Abe in forum Trouble ShootingReplies: 9Last Post: 26-04-2003, 01:06 PM
