    deven64t's Avatar
    deven64t Guest
    Walk in freezer wont cool below 5 degrees
    I changed out the skid on the freezer due to the last comp would not pump down below 10 psi also noticed brown oil when I removed my hoses, So I changed the skid, TXV , used flush and nitrogen to blow out the evap and lines, lots of nasty oil came out. I also removed the feeder tubes and blew out each set of tubes in the evap, NOW, started the unit up,,it had a low DT , around 8 deg ,, and frost started to form instantly across the evap and onto the suction line,,, as the box approched 5 deg my DT drop to 2 deg. I know this isnt enough info,,Ill get more when I go back,,But I adjusted my TXV to reach Factory specs ,,< 404a > im running a - 20 saturation {Evap } but my sub cooling wont change ,,,it stays in an area of -1 to 3 deg,,the factory said to run a 5 deg subcooling,, sight glass is full,,I know this because I tried to raise my sub and It started to Bubble,,I even tried to over charge the unit,,,but stop at 400psi , Do you think the Inside of the evap is coated with oil??
    I will return ASAP with this info
    Evap air in temp
    Evap air out temp
    Low side pressure
    Suction line temp at TXV bulb
    Cond air in temp
    Cond air out temp
    High side pressure
    Liquid line temp at receiver outlet
    Sep 2008
    Thailand
    40
    Re: Walk in freezer wont cool below 5 degrees
    Did you check the copper piping? Maybe it is bent somewhere along the liquid or suction line.
    11,025
    Now that you have adjusted the TXV fault finding is going to be that much harder.
    Auckland
    74
    3,357
    37
    Did you gas charge or liquid charge the R404A.
    magoo
  1. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  2. Liebherr Fridge freezer 13 and -18 degrees
    By jensenengland in forum Trouble Shooting
    Last Post: 05-07-2009, 07:48 PM
  3. Beko Frost Free Fridge Freezer failing to cool
    By Derek Max in forum Trouble Shooting
    Last Post: 19-06-2009, 07:31 PM
  4. Wirlpool FF Issue - fridge warm, freezer cool
    By kinetic100 in forum Domestic
    Last Post: 02-04-2008, 01:36 AM
  5. walk in freezer refrigeration sizing?
    By trammd in forum Technical Discussions
    Last Post: 02-11-2006, 11:56 AM
