Results 1 to 8 of 8
Thread: NVQ 3 online test
08-07-2009, 09:59 AM #1
NVQ 3 online test
Hi, was wondering if anyone in the UK has info on practice test questions for the online tests 301 and 302. Has anybody recently done it, and do they ask much on cascade systems. I am not at college, but am doing the tests as an "experienced" person. I have already done the 101, 201, 202 tests with no problem, but seeing I mainly work on chillers and larger packaged units they advised me to rather skip the NVQ2 porfolio and complete the NVQ3.
Any takers
08-07-2009, 10:38 PM #2
Re: NVQ 3 online test
1. What are the two axes that make up a typical system balance graph?
a. Pressure and temperature
b. Capacity (kW) and saturated suction temperature
c. Pressure and condensing temperature
d. Compressor capacity and superheated discharge temperature
2. What two temperatures have an affect on the humidity levels within a refrigerated space?
a. Suction and evaporating
b. Air and condensing
c. Evaporating and condensing
d. Evaporating and air
3. What happens to the capacity of the air-cooled evaporator if the air circulation is reduced?
a. Remains the same
b. Increases
c. Decreases
d. Freezes the product
4. What is the surface area of an evaporator if the velocity of air required is 2 m/s for an airflow rate of 0.2m³/s?
a. 10 m²
b. 0.4 m²
c. 0.2 m²
d. 0.1m²
5. A small condensing unit is designed to work at a selected ambient temperature, what happens to the capacity (kW) of the unit if the ambient temperature increases above design conditions?
a. Remains the same
b. Increases
c. Decreases
d. Non of the above
6. The heat load from a small evaporator fan motor is 0.308kW over a 24 hour running period. If the motor has a running time of 16 hours within a 24-hour period, what is the actual heat load from the motor?
a. 0.0193 kW
b. 0.462 kW
c. 0.492 kW
d. 7.392 kW
7. The rated capacity taken from a manufacturers catalogue for of an evaporating to air temperature difference of 6 K is 5.5 kW. If the final calculated heat load is 4.5 kW, what is the actual evaporating to air temperature difference?
a. 4.9 K
b. 7.3 K
c. 27 K
d. 33 K
8. A manufactured air cooled evaporator is normally designed around an evaporating to air temperature difference of?
a. 3 to 4 K
b. 4 to 5 K
c. 5 to 6 K
d. 6 to 7 K
9. When a condensing unit and evaporator are connected into a system the relationship established between the two is known as the?
a. System balance point
b. Capacity point
c. Evaporating temperature
d. Condensing temperature
10. Name the correction factor that needs to be taken into account when calculating the size of an air-cooled condenser?
a. Log mean temperature
b. Temperature difference
c. Ambient temperature
d. Altitude
11. One of the main criteria used to select a thermostatic expansion valve is the?
a. Oil
b. Inlet size
c. Refrigerant type
d. Outlet size
12. An externally equalised thermostatic expansion valve takes into account?
a. Pressure drop across the condenser
b. The external Phial/Bulb temperature
c. Pressure drop across the evaporator
d. Oil Logging
13. If the speed of a belt driven compressor is reduced, the suction pressure will tend to?
a. Stay the same
b. Increase
c. Decrease
d. Behave erratically
14. 20 kg of water at 0° C is to be frozen to ice. How much heat is to be removed?
{Take the latent heat of ice to be 335 kJ\kg.}
a. 0.06
b. 16.75
c. 6700
d. 7200
15. If 7200 kJ of heat is to be removed from a quantity of peas in 10 minutes, the rate of heat removal in Kilowatts (kW) is?
a. 0.0083
b. 12
c. 720
d. 4300
taz.
08-07-2009, 10:40 PM #3
1. Vacuum gauges measure pressure
A) Lower than atmospheric pressure
B) Above atmospheric pressure
C) Above 30 inches of mercury
D) Below 200 psi
2. Dial stem thermometers are used for
A) Angle measurements
B) Temperature measurements
C) Pressure and Temperature measurements
D) Temperature and vacuum measurements
3. Compound gauges measure
A) Below and above atmospheric pressure
B) Absolute pressure
C) Absolute and gauge pressure
D) High discharge pressure
4. Which of the following is a function of a complete air conditioning system?
A) Temperature and humidity control
B) Air Filtering, cleaning and purification
C) Recirculation and air distribution
D) All of the above are functions of a complete air conditioning system.
5. What makes up the main living portion of the atmosphere
A) Oxygen, nitrogen, carbon monoxide and hydrogen
B) Oxygen, nitrogen, carbon dioxide, hydrogen, and sulfur dioxide
C) Oxygen and hydrogen
D) Oxygen, nitrogen, carbon dioxide
6. In what form does water exist in the air?
A) Solid
B) Liquid
C) Vapour
D) None of the above
7. Dry bulb and wet bulb thermometers indicate
A) Air temperature
B) Relative humidity
C) Amount of moisture and heat in the air?
D) All of the above
8. What happens to the moisture absorption properties of air as the temperature decreases?
A) Decrease
B) Increase
C) Remain the same
9. When is air heated, the relative humidity
A) Decreases
B) Remains constant
C) May increase or decrease, depending on the air temperature
D) Increases
10. The chemical formula for ozone is
A) 01
B) 02
C) 03
11. Pressure – temperature condition of a substance in equilibrium (i.e. solid liquid and vapour states) is called
A) Triple point
B) Dew point
C) Boiling point
D) Melting point
12. Total heat is equal to the sum of
A) Low and high temperature
B) Sensible and latent heat
C) Sensible heat and superheat
D) Latent heat and heat rejected
13. Total heat rejected (THR) in a condenser equal to
A) Heat rejected in the metering device
B) Heat absorbed in evaporator plus heat of compression
C) Heat absorbed in metering device
D) Heat of evaporation plus latent heat
14. Degree of hotness or coldness as measured by a thermometer is called
A) Heat energy
B) Temperature
C) Thermister
D) Thermostat
15. Which of the following describes the ability of a material to transfer heat
A) Temperature
B) Heat exchanger
C) Thermal conductivity
D) Condenser
16. Heat transfer through solids by compact molecular vibration is called
A) Conduction
B) Convection
C) Fusion
D) Radiation
17. Which of the following best describes heat transfer in fluids (liquid or gas)
A) Conduction
B) Convection
C) Fusion
D) Radiation
18. Heat transfer by energy waves through space or air where the space is not heated is called
A) Conduction
B) Convection
C) Fusion
D) Radiation
19. What is the right name of a pressure gauge for gases and liquids
A) Barometer
B) Manometer
C) Hygrometer
D) Tachometer
20. Give a close answer to an instrument for measuring atmospheric pressure
A) Barometer
B) Manometer
C) Hygrometer
D) Tachometer
21. An instrument for measuring the humidity of the air is called
A) Barometer
B) Manometer
C) Hygrometer
D) Tachometer
22. State the units for Force
a) Pa
b) kJ
c) km
d) Newton (N)
23. Give the units for work and energy.
a) kJ
b) kPa
c) Watt
d) kN
24. Define power and state the unit
a) Force in action; kW
b) Work done under pressure; kW
c) The rate of distance x time; Watt
d) The rate at doing work; Watt
25. State the formula for Power
a) work done / time
b) distance x time
c) force x distance
d) work done x time
26. Explain what is Pressure
a) force per unit area
b) force x distance
c) mass per unit force
d) force x area
27. What is the S.I Unit of pressure
a) N/m2
b) 1/ Pa
c) Pa/ kg
d) N/ kg
28. What is the relationship between absolute pressure and gauge pressure ?
a) Atmosphere = Absolute + Gauge
b) Atmosphere = Gauge - Absolute
c) Absolute = Gauge - Atmosphere
d) Absolute = Atmospheric + Gauge
29. Name two pieces of equipment used in pressure measurement .
a) Tachometer and Bourdon Tube gauge
b) U – Tube manometer and Bourdon Tube gauge
c) Hydrometer and U-Tube manometer
d) Thermometer and U-Tube manometer
30. What are the temperature scales relevant to refrigeration ?
a) Celcius and Pascal scales
b) Kelvin and Celcius scales
c) Pascal and Kilogramme scales
d) Pascal and Kelvin scales
31. What happens to the temperature of a liquid if the Internal kinetic energy is increased ?
a) Temperature increases
b) Temperature decreases
c) Temperature stays the same
d) Temperature changes
32. What changes occur in a liquid if the internal potential energy is increased ?
a) Change in volume
b) Change in temperature
c) Change of shape
d) Change of state occurs
33. Define the saturation temperature of a liquid.
a) The lowest or highest point of a liquid
b) The saturation of cold or hot liquid at a given pressure
c) The temperature of a fluid in the liquid state
d) The highest or the lowest temperature at which a fluid can exist as a liquid at a given pressure.
34. What is saturated vapour?
a) Vapour at its highest pressure at constant temperature.
b) Vapour at its highest temperature at a given pressure.
c) Vapour which has the same temperature as liquid
d) Vapour at its lowest temperature for a given pressure.
35. Which of the following closely describes Specific Volume
a) m2/kg
b) m3/kg
c) kg/m3
d) m3/kJ
36. Explain what is Superheated Vapour
a) Very hot vapour at constant pressure.
b) Vapour which has low moisture content.
c) Hot vapour at the same temperature and pressure.
d) Vapour at a higher temperature than its saturated. condition but at the same pressure.
37. Which of the following refers to ‘Subcooled liquid’.
a) Fluid in the liquid state which has undergone cooling at a given pressure.
b) Liquid which is being cooled at constant pressure.
c) Liquid at its lowest temperature and a given pressure
d) Liquid at a temperature below its saturation temperature at a given pressure.
38. What Quantity of Heat is required to raise the temperature of 9 kg of water from 20 ºC to 25 ºC (Given C = 4200 J/kg K for water)
a) 189 kJ c) 230 kJ
b) 198 kJ d) 112 kJ
taz
.Last edited by taz24; 08-07-2009 at 10:55 PM.
09-07-2009, 07:23 AM #4
Wow Taz, thanks for the effort!
09-07-2009, 01:10 PM #5
very flash taz
13-07-2009, 04:12 AM #6
thanks so much Taz!!
your time is much appreciated!
17-09-2009, 08:57 PM #7
Is the apprentship "refrigeration engineer" in the uk only based on a full time on the job training and a part time academic training at a college? To do a online test to get a "NVQ". Could you explain the apprentship in the uk, plz?
kind regards
kevin
28-10-2009, 08:35 PM #8
Kevin
in most cases the NVQ has a practical part which requires the apprentice to prove competence aginst the award standards and a knowledge part which requires the apprentice to prove his underpinning knowledge of the refrigeration industry and its technolgy and science which in the UK is proved by taking three online exams for the basic qualification two more for the advanced award.
Ian
Pooh
Daikin VRV II Test Mode Failure
By KISS KISS BANG in forum Air ConditioningReplies: 8Last Post: 30-05-2010, 08:54 PM -
Test
By bigblock468 in forum New to REReplies: 3Last Post: 04-06-2008, 11:16 PM -
Refrigeration plant Hydro test
By psrao in forum New TechnologiesReplies: 17Last Post: 09-04-2008, 12:05 AM -
air cooling and heating coil test
By Lc_shi in forum Technical SpeculationsReplies: 8Last Post: 23-02-2006, 01:15 AM -
`skills / trade test???????
By pagey in forum Chit Chat & Service StoriesReplies: 26Last Post: 24-03-2004, 03:31 PM
