07-07-2009, 05:58 PM #1
Trane CGAH 235 Chiller communication port
Hi to everybody, I was wondering if you could help me locate this chiller's communications port? Here is a picture of SMM module and this RJ11 connector beside it. Thank you in advance!
07-07-2009, 07:58 PM #2
Re: Trane CGAH 235 Chiller communication port
That's the modem port.
The yellow and white wire below the flatcable are on the comm port.
07-07-2009, 08:44 PM #3
08-07-2009, 04:00 PM #4
This comm port uses a protocol that only we, Trane, can read. How ever should you want to we can install a BCU and than you can communicate with the BCU over BACnet/IP, which in turn communicates with the chiller(s).
Trane chiller
By Lman in forum Trouble ShootingReplies: 4Last Post: 13-11-2009, 03:51 PM -
AEC Pinical chiller with trane comp
By cptrdbrd in forum CommercialReplies: 1Last Post: 28-10-2009, 09:47 PM -
Problem with Trane RTAD100 chiller.
By on4hf in forum Trouble ShootingReplies: 8Last Post: 14-10-2009, 09:01 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM
