07-07-2009, 06:10 AM #1
goodman Cpkj60-1c Reversing valve
I had my dad ac go out this weekend. The tansformer was burnt out. Replaced it and then started the unit. It is a Five ton heat pump. The unit would not go into cool as the valve would not move over. Then I smelled burning. The tansformer was getting hot, then the unit stopped. I let it cool down and went out side to check the uint. It came back on when I removed the power to the coil on the reversing valve. Has any one had the coil on the valve take out a tanformer. The Tansformer is 40 va big enought for this unit.
07-07-2009, 12:39 PM #2
Re: goodman Cpkj60-1c Reversing valve
thats what happens when it is not protected by fuses,your transformer out put is like your power supply but it is protected i hope by the like
07-07-2009, 02:53 PM #3
it is fused on the incoming power only. But you have seen that happen?
08-07-2009, 01:11 AM #4
no different than 240v on primary 240v on secondary used say as an isolation transformer running fan motors. yes i have seen it had to replace a $350 tranny because $2 inline fuse was not fitted to fan motor wiring.
08-07-2009, 03:42 AM #5
Just making sure. Thank you
15-07-2009, 01:54 AM #6
changed it this weekend and it worked not more tans
former melt down.
15-07-2009, 02:58 PM #7
hope you protected the trans
stuck reversing valve
By kling65 in forum Heat PumpsReplies: 10Last Post: 26-07-2010, 12:22 AM -
Sporlan subcooling valve
By BESC5240 in forum Technical SpeculationsReplies: 8Last Post: 13-10-2008, 03:23 PM -
Diagnosing reversing valve vs scroll compressor?
By Larry2 in forum Technical DiscussionsReplies: 16Last Post: 10-05-2008, 01:25 AM -
Reversing valve problem?
By coffeebreak in forum Heat PumpsReplies: 18Last Post: 29-02-2008, 12:19 AM -
quiet 4 way reversing valve
By steveg in forum Air ConditioningReplies: 7Last Post: 06-10-2006, 11:27 AM
