Results 1 to 1 of 1
07-07-2009, 02:00 AM #1
Noobie looking for some technical stats on a Edgestar Windowless
I am needing to find some technical stats for a Edgestar windowless ac/heat pump unit. I bought this unit for over $700.00 13 months ago and due to the fact that it was 30 days out of warranty theyt basically said tough. I am looking to see if anyone knows how much r-22 and where my gauges should read. I know if it has too much the compressor overheats and too low it freezes up. It has a slow leak somehere (or so I think) but until I get the pressures dialed in I can't even begin to diagnos. If this helps the unit is a Edgestar AP550 with a Rechi Precision compressor model #44r261a config # G-FES. Thanks and I look forward to all the help.
