Results 1 to 17 of 17
    gordo_guero's Avatar
    gordo_guero Guest
    Smile Your Opinion guys, please!
    I am 31 and have been A/C Engineer now for 4 and a half years, starting back when a friend got me into a company as his 'mate' and have been (up until recently due to redundancy) installing jobs with a 'mate' under me for a good few months.
    I have had no luck on the job front, I am thinking, due to my lack of A/C Qualifications.
    Now here's the question....
    Do you think spending the money to get qualified (about £1600 for a 6 week course so I believe) is the way forwards or should I look at simply getting my safe handling and percivere with the jobhunting???
    All replies greatly appreciated ...
    Aug 2007
    Sydney
    1,083
    23
    Re: Your Opinion guys, please!
    Hi gordo
    If you can afford to do the course do it. I have been made redundant recienly too. There are about one tenth of jobs normally advertised in the past few months so Im not holding my breath. If you get qualifications you might consider subbing in the interum. Good luck
    Aug 2008
    Baltics
    786
    I would not give them up my 1600. Its a price of a good vac pump, or maybe a recover unit. You have experience, a grip on A/Cs. Become self-employed.
    Oct 2007
    Not Sure?
    Any and all training is a must. A person that is always learning is a good employee that will always have a job with us.
    Seriously! What was that guy thinking.
    Pentane rocks!
    Auckland
    74
    3,357
    37
    If you are keen, well you have to start somewere. 1600 notes for 6 weeks is going to give the basics. You then start learning if some one gives you a job.
    Hell I did a 9000 hour apprenticeship a hundred years ago, and still learning everyday.
    If you can afford it do it.
    May 2008
    66
    802
    good money whasted, the only course i took was evening school for two years,so then i could PROUVE i had some notice of refrigeration.everything else i learnd the hard way, whit ups and downs, books, collueges,E-net and so on. i am 52years young and still happy to learn from time to time. become a refrigeration engineer, and find yourself in a never ending story.
    Ice
    Davidy's Avatar
    Davidy Guest
    Hey, I've been in the field 23 years. Never did I ever dream I would make $41/hr in the states. Press on and keep working in the field. Take any and all classes and training you can afford, it will pay you back in spades. You will struggle at first. Once you make Journeyman, you will never regret it. I can get a job anywhere. When you get 10 to 15 years experience behind you, you just won't believe the kind of money you have. But it takes hard work, to whom much is given, much is expected. I encourage you to roll up your sleeves and work hard. It's a great field if you stick with it. You can even branch off to specialize in one of the various specialties like refrigeration, shock chambers, chillers, controls... Good luck and stick with it...
    May 2006
    India
    74
    399
    learning never ends may be any field. i have come across people committing silly things even after several years of field experience. Hence a good basic course + field experience + willing to keep eyes/ears open can be a good idea to be in this field
    Jul 2009
    west midlands
    70
    8
    Hi Can you experienced A/C engineers help me. I have been called to a job which has lost all its 407c. I found the leak repaired it and pressure test all ok.
    Now how do i check the oil is ok before charging the system?.ita a sealed rotary compressor no oil site glass?
    Regrads Eamonn
    May 2008
    66
    802
    you have to weld a separate valve on the HP side as close as possible to the comp.
    i only do things like that if i have doubts about the amound or quality of the oil.
    ice
    BoilerBoy's Avatar
    BoilerBoy Guest
    Get Papers!
    You will never go hungry. In fact, you make it back hand over fist.
    Auckland
    74
    3,357
    37
    BoilerBoy.
    Papers are worth a pinch of shyte with out experience. That is what the whole industry is suffering from. Geeks with a long set of qulaification papers, and no experience.
    BoilerBoy's Avatar
    BoilerBoy Guest
    I concure. Here in Canada, you can't get a job without papers. Kinda makes it hard to get that hands on experience if you can't work. I will never tell someone that seeking knowledge is a form of folly. I'm pretty sure that is why this forum is here. Then again, I'm new. New to the forum. Been at this awhile. Wouldn't you know it? I learn stuff everyday. That is one of the best things about this field.
    Jan 2009
    united kingdom
    70
    31
    Providing you found the only leak and no large oil blow was found around it, its safe to assume the oil charge is still within the confines of the system.( having said that, do you know any service history of past service calls). When you charge, use an amp meter, and watch the running current,It should climb slowly as compressor load goes up.Keep listening to the compressor note, any sudden change in noise or a rapid increase in running current will indicate the pot is starting to seize. so be ready with the lock stop button. good luck.
    Jan 2009
    united kingdom
    70
    31
    There is no easy way to check,If you did not find to much oil around the leak you could assume the oil is still in the system. Charge with an amp meter. listen for sudden compressor noise change. and a sharp rise in running current,if this happens its going to seize so be ready with the lockstop button, good luck.
    Jan 2009
    jax, fl,
    23
    chiller man. you have killed a lot of compressors havent you. HAHAHa
    Jan 2009
    united kingdom
    70
    31
    Not at all old chap when your as good as me you can take short cuts, but never mind, you may just get the hang of it ------ one day! Its called Knowlage. Im suprised, your as old as me. Remember, there are enginners and ENGINEERS! -------Sleep well.
  1. Hi guys
    By slant6ref in forum Chit Chat & Service Stories
    Last Post: 13-08-2008, 02:08 AM
  2. Need second opinion for this Carrier Unit I am working on..
    By David45Morton in forum Air Conditioning
    Last Post: 10-03-2008, 08:45 AM
  3. Are we all fridge guys?
    By LRAC in forum Chit Chat & Service Stories
    Last Post: 20-05-2007, 10:39 PM
  4. Hi Euros, I found you guys on HvacCommunityNetwork.com
    By isitfixedyet in forum New to RE
    Last Post: 24-04-2007, 10:46 PM
