Results 1 to 38 of 38
Thread: Oil return problems
Threaded View
29-07-2004, 03:10 PM #7
Re: Oil return problems
Hi Peter.
R-12 was the best with oil return. Never had any problems.
R-22 is good but not as good, R-404 is new and now you know that it has problems with oil, but maybe pipes diameter should be changed or the pipes in the evaporator should be arrange different.
I can see that the industry is still struggling with the new refrigerants.
Its something you will have to find out by yourself, very slow.
Then you will be an expert on "oil return in refrigeration systems operating with R-404A"
Chemi
R-508B oil return problems
By Hank Hill in forum IndustrialReplies: 43Last Post: 05-02-2010, 05:58 PM -
Problems LG don't want you to know about
By Andy W in forum Air ConditioningReplies: 11Last Post: 16-02-2006, 04:52 PM -
oil pressure problems on air dryer
By edge in forum Trouble ShootingReplies: 1Last Post: 16-07-2002, 02:10 PM -
return air
By subzero*psia in forum Air ConditioningReplies: 1Last Post: 12-07-2001, 04:02 PM
