04-07-2009, 06:20 PM #1
Daikin VRF inverter scroll compressor
Hi, anyone ever tried to replace a Daikin VRF inverter scroll compressor with a Daikin VRF standard full speed scroll compressor? Can it be work? Thank you.
08-11-2009, 07:42 PM #2
Re: Daikin VRF inverter scroll compressor
the unit will not like it as it is looking at compressor current and frequency, the unit will not run.
09-11-2009, 10:04 PM #3
as brunstar says the unit wont even start as measuring the compressor won't get the ok from the inverter PCB and the unit going to get a alarm code, try to prohibit the compressor and run with the compressors that are left (if there are any).
- until replacement of curse the exact model as the existing
Daikin Inverter Board / Compressor issues
By Greengrocer in forum Air ConditioningReplies: 12Last Post: 21-04-2009, 10:12 PM -
Electrical Frequency range of Inverter Compressor of Daikin VRV
By biengates in forum ElectricalReplies: 6Last Post: 05-02-2009, 08:14 AM -
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Difference between AC Inverter & DC Inverter Compressor
By berrytmy in forum New TechnologiesReplies: 0Last Post: 24-04-2008, 11:43 AM -
seized inv compressor
By flash in forum Air ConditioningReplies: 2Last Post: 09-04-2008, 06:56 PM
