Threaded View
09-11-2009, 10:04 PM #3
Re: Daikin VRF inverter scroll compressor
as brunstar says the unit wont even start as measuring the compressor won't get the ok from the inverter PCB and the unit going to get a alarm code, try to prohibit the compressor and run with the compressors that are left (if there are any).
- until replacement of curse the exact model as the existing
Daikin Inverter Board / Compressor issues
By Greengrocer in forum Air ConditioningReplies: 12Last Post: 21-04-2009, 10:12 PM -
Electrical Frequency range of Inverter Compressor of Daikin VRV
By biengates in forum ElectricalReplies: 6Last Post: 05-02-2009, 08:14 AM -
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Difference between AC Inverter & DC Inverter Compressor
By berrytmy in forum New TechnologiesReplies: 0Last Post: 24-04-2008, 11:43 AM -
seized inv compressor
By flash in forum Air ConditioningReplies: 2Last Post: 09-04-2008, 06:56 PM
