    Apr 2008
    ENGLAND
    Toshiba Air Conditioning fault codes,
    Does anybody know what these codes are ?
    01 06 and 1E are the ones that have been showing at a site I have been working at.
    4,698
    Re: Toshiba Air Conditioning fault codes,
    Hi suctionheader .
    Download from the link I have provided and the codes are explained.
    Good Luck Grizzly
    http://www.mediafire.com/?sharekey=0...b07cc7f7a4c543
    Not all the codes you state are there though.
    What is the actual unit you have a problem with?
    5,668
    Follow this link
    http://www.realtime-controls.co.uk/p...iss2.00.00.pdf
    The first part of the code is the unit number, the second (06) relates to how many times the electronics have tried before finally giving up and the last part is the actual error - in this case, High Dischage pressure
    May 2006
    Hayling Island, UK
    143
    Hi Suctionheader,
    Sorry Frank you are wrong. There is no count for electronics trying to start then giving up. (but some models have a compressor start count)
    I think the codes should read
    01.0b
    01.1E
    The 01 is the master unit
    06 is actually 0b and is a float switch trip - check drains \ pump operation.
    1E is the compressor discharge temerature exceeded 130C - check air flows (in & out), gas charge & Td sensor.
    Hope this helps
    Loops
    Jan 2003
    East Anglia
    1,160
    Aug 2001
    1,046
    ............ Listen to what Loops says, he knows the kit inside out.
    Mar 2007
    manchester
    63
    does it matter what order you wire the p q wiring in a multi modular 407c?
    May 2006
    Hayling Island, UK
    143
    Paddyaircon,
    I'd sugest you should have started a new thread for this enquirey but seeing as you've asked a question........
    The PQ network on the old R407c 2-pipe modular multi is a non-polarised network. Just wire from one end to the other (not ring main style).
    You'll need a 1.5mm2 2-core screened cable minimum.
    Loops
    May 2006
    Norwich
    134
    Just had a call from one of our engineers and hes got P10 code up on the controller.
    Its a RAV unit,
    I told him to ring Toshiba Technical, as P10 isnt listed :lol:
    Aug 2004
    744
    P10 is "Float switch open circuit (high water level)"
    Eggs
    Jan 2003
    East Anglia
    1,160
    Thanks Egg,
    I have just come back from another call with that fault and after going through all my Tosh books i couldnt find anything either. Had booked it to go back after speaking to Toshiba but thats saved me a phone call
    Latte
  1. Toshiba Fault codes
    By bernard in forum Air Conditioning
    Last Post: 03-08-2010, 11:09 AM
  2. Toshiba cassette fault codes
    By glenn1340 in forum Air Conditioning
    Last Post: 05-01-2009, 08:38 PM
  3. toshiba a/c fault codes
    By fsfd1 in forum Trouble Shooting
    Last Post: 30-09-2008, 07:10 PM
  4. toshiba fault codes
    By COOL BOB in forum New to RE
    Last Post: 09-12-2007, 08:18 AM
  5. Toshiba a/c fault codes
    By Latte in forum Air Conditioning
    Last Post: 27-09-2007, 09:33 PM
