Results 1 to 1 of 1
Thread: Interference Problem??
04-07-2009, 06:13 AM #1
Hello All,
I checked a system today I think may be encountering some kind of EMI Interference problems.
What is the proper procedure for running the communication RS 485 line? I did notice it seems to be installed ib the "daisy chain" method. I am unsure of how the communication wiring should be grounded?
The power coming into the unit comes from the building panel ran underground to the outdoor unit. Is it possible I could be encountering some earth leakage of some kind?
The daisy chain communication wiring is grounded to the equipment case, but not the voltage ground.
The wiring is 1mm2 shielded,
Thanks for any information.
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM -
problem with vfd interference
By joe magee in forum Supermarket RefrigerationReplies: 5Last Post: 07-11-2007, 10:58 PM -
RFI Interference from Fridge/Freezer
By pathfinder in forum Trouble ShootingReplies: 6Last Post: 19-03-2005, 11:50 AM
