Results 1 to 2 of 2
Thread: DAIKIN Faulty PCB
04-07-2009, 03:48 AM #1
DAIKIN Faulty PCB
Hi Technicans,
l`ve been working on a Daikin unit l`ve only got the indoor model RY100KUY1.There is an error code H3.Daikin told me that it is either a faulty hp switch or outdoor pcb.l tested contiunty with the hp switch its fine.But where the hp switch connects to pcb l checked resistance and there is no resistance.
So l got a new pcb from daikin and tested the resistance l`m getting 186k resistance for a second and it goes back to 0k is that normal ,because l thought that it should be 186k all the time.l have not been to the job with new pcb.
thanks
04-07-2009, 07:38 PM #2
Re: DAIKIN Faulty PCB
Did the system reset and run? is it 407c or 410a?
al
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin FDYQ250M
By carl in forum Air ConditioningReplies: 7Last Post: 11-08-2009, 12:56 AM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM
