Thread: Ashrae Question
03-07-2009, 06:54 AM #1
Ashrae Question
Hello friends,
I am confused about Ashrae, thus I need to ask you about it.
I use 2006 ashrae and I think there is a problem in “Suction, Discharge and Liquid Line Capacities in Kilowatts for Refrigerant 404 a (single or High-Stage Applications)”. The problem is in the liquid line section at the header. It seems like this;
Liquid Lines (40 °C)
See note a
Velocity = 0,5 m/s ∆T=2 K/m ∆T=5 K/m
According to me, the ∆T’s are supposed to be 0,02 K/m and 0,05 K/m. Could you please confirm me which one is correct ? 0,02 – 0,05 K/m or the current ones (2 K/m ; 5 K/m) ?
Does anyone know the answer ? Thanks people.
19-07-2009, 07:53 AM #2
Ashrae Question
Thanks for the repies, one more question, which way do you spin the pump from the dizzy side to prime it, C or CC? Nevermind: Stupid question I already know the answer to.
24-07-2009, 09:08 AM #3
Re: Ashrae Question
Here is the reply I got from Ashrae;
Dear Mr. Dirikan:
Thank you for your message. After locating the source files for the tables, which were last revised in 2002, we believe that the values for delta t in Tables 6 to 9 should indeed be 0.02 and 0.05 K/m as you mentioned below. We will issue a correction notice under Handbook Corrections on the Handbook page of the ASHRAE Web site at the following link:
We appreciate your taking the time to alert us to this matter.
Sincerely,
Mark Owen
Pretty Hard Question about calculating a vacuum.....help
By halfcan in forum TrainingReplies: 1Last Post: 02-06-2009, 04:01 PM -
Another Ashrae Handbook question.
By Chunk in forum Refrigeration BooksReplies: 0Last Post: 16-04-2008, 08:38 PM -
Refriferation cycle question
By ozmecheng in forum FundamentalsReplies: 32Last Post: 26-03-2008, 10:38 PM -
Need copy from ASHRAE
By Peter_1 in forum FundamentalsReplies: 1Last Post: 08-01-2007, 08:59 AM -
Urgent, Kirchoff question
By Peter_1 in forum FundamentalsReplies: 4Last Post: 20-01-2004, 03:12 PM
