    Jan 2006
    Australia
    47
    92
    fujitsu inverter dead
    unit
    fujitsu inverter
    indoor model:ABTA45LAT(UNDERCEILING CASSETTE)
    out door model:AOTA45LATL
    problem: bth indoor and outdoor unit nt running
    indoor lights all off
    my diagnosis
    OUTDOOR UNIT
    checked voltage on outdoor ,L-N =240V
    checked voltage N-1=240V
    CHECKED VOLTAGE 1-2=240V
    disconnected 3 from terminal block and checked voltage, 2-3=90v-125v
    checked voltage, 2 and the disconnected 3 which goes to indoor got 84v
    INDOOR UNIT
    CHECKED 1-2 =240V
    CHECKED 2-3=30V-90V
    TO CHECK
    COMPRESSOR MOTOR WNDINGS RESISTANCE
    BTH FAN MOTORS WINDING RESISTANCE
    Any input welcome thank you
    Split Croatia
    57
    6,151
    36
    Re: fujitsu inverter dead
    What kind of remote controler you got.
    Check Fuse in Filter PCB.
    >> If Fuse is open, check if the wiring between Terminal and Filter PCB
    is loose, and replace Fuse.
    Check Varistor in Filter PCB.
    >> If Varistor is defective, there is a possibility of an abnormal power supply.
    Check the correct power supply and replace Varistor.
    Jan 2006
    Australia
    47
    92
    Nike 123 ,The remote controller is a wireless hand held one .
    Jul 2007
    Australia
    1,845
    Dumb question, but you've tried pushing the auto button on the indoor unit to make sure it isn't a remote control or reciever problem?
    Is this a DOA unit or has it worked before?
    edit: are you sober yet nike? Have you had a look at that PM i sent?
  1. Testing Inverters
    By fridge doctor in forum Air Conditioning
    Last Post: 15-06-2011, 06:52 AM
  2. Fujitsu inverter wiring
    By Tbird650 in forum Heat Pumps
    Last Post: 21-05-2009, 01:12 PM
  3. Daikin Inverter Board / Compressor issues
    By Greengrocer in forum Air Conditioning
    Last Post: 21-04-2009, 10:12 PM
  4. R22 Fujitsu FCUs on new Inverter Multi-Condenser?
    By Makeit go Right in forum Air Conditioning
    Last Post: 09-01-2007, 11:22 PM
  5. Fujitsu AST12LSBCW Inverter; cooling issues
    By AussieGuy in forum Air Conditioning
    Last Post: 30-01-2006, 05:13 AM
