    Dec 2008
    India, USA
    37
    Question Scroll compressor
    I heard scroll compressors of smaller cubic capacity say 90 cc can have performance more than 170cc Piston compressor. Is it so?
    What is the logic behind that?
    Also i heard piston compressors are better than scroll compressors at lesser speeds. Why and how?
    Jan 2007
    India
    65
    Re: Scroll compressor
    In general, scroll has high volumetric efficiency say 97% + than the reciprocating compressor whreas the 65 to 70% is the voulmetric efficiency. So for the same capacity the displacement of Scroll is approx. 30 % smaller than Pisto type.
    The efficiency of scroll is alwas better than piston compressors as it has lesser moving parts than recips. Infact variable speed scrolls are widely used in comfort Ac application.
    Dec 2008
    Portugal
    48
    1,020
    Quote Originally Posted by sendhilkmar View Post
    On the piston compressors The volumetric efficiency it depends of the pressure ratio and politropic exponent of the vapor refrigerant and the dead volume.
    If you are talking about a single stage for AC I would say that the volumetric efficiency will be around 85%.
  1. About Copeland ZB scroll compressor
    By ernestlin in forum Technical Speculations
    Last Post: 27-08-2009, 08:39 AM
  2. Copeland scroll compressor - running capacitor
    By desA in forum Fundamentals
    Last Post: 23-06-2009, 08:05 PM
  3. Scroll Compressor Seizure
    By jwasir in forum Trouble Shooting
    Last Post: 08-06-2008, 12:52 PM
  4. Replies: 7
    Last Post: 19-06-2007, 10:51 PM
  5. Scroll Compressor
    By dwallan in forum Commercial
    Last Post: 30-07-2001, 04:18 AM
