01-07-2009, 11:51 PM #1
Liebherr Fridge freezer 13 and -18 degrees
Hi, First time here be gentle!!
I have a Liebherr fridge/freezer 7081 630-03 Premium biofresh, bought in 2001.
The freezer works find and lives at -18. The fridge performance has been deteriorating over the last month and is now showing a constant 13 degrees on the fridge gauge.
The location is in the kitchen.
The lower part of the fridge is the biofresh region and on my temperature gauge is showing 3 degrees.
It's like the cooling isn't reaching the top of the fridge.
There is a fan at the top of the fridge which is working (and stops when the door is opened)
Does the unit just have one freezing device which is shared (in a controled way) between the fridge and freezer?
Does anyone have an idea what the problem is?
I have defrosted it completely and it hasn't solved the problem.
help!
David
02-07-2009, 12:22 AM #2
Re: Liebherr Fridge freezer 13 and -18 degrees
Replying to my own post here.
I've just spotted the model number of my Liebherr, it's
KIKB 3146 Index 22A/007
Hope this helps
David
03-07-2009, 09:57 PM #3
this appliance has 2 compressors, 1 for freezer and 1 for fridge/biofresh. If you've tried full defrost of top compartment then it is likely to have refrigeration system fault - call engineer
05-07-2009, 07:48 PM #4
Thanks Happy for replying. I must admit that I'm dissapointed by this forum. I was expecting some cleaver and interesting analysis of the problem which might guide me towards a solution.
Nevermind....thanks anyway
Bosch fridge freezer - fridge strange behaviour
By Geoff75 in forum DomesticReplies: 1Last Post: 24-03-2009, 07:47 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Liebherr Integrated fridge freezer ICN 3056
By redjane11 in forum DomesticReplies: 5Last Post: 03-04-2008, 11:10 PM -
Liebherr Fridge Freezer fault
By bedroom fitter in forum DomesticReplies: 3Last Post: 21-01-2008, 01:21 AM
