Results 1 to 13 of 13
Thread: Stench !!
01-07-2009, 01:35 PM #1
Stench !!
We've just got our airco, brandnew.
It's been on for about 2 days now.
Problem is that when I put it on, it's like a sewer running through my house !
It really stinks...
What can I do about that because it's not very nice to be in such a smell all day long !
Hope somebody can help us...
Regards,
Joke
01-07-2009, 05:56 PM #2
Re: Stench !!
What is the humidity in the house?
Do you have carpets right through the house?
01-07-2009, 06:02 PM #3
Re: Stench !!
Might not fan cage (ventilator) be scratching the case in the inside unit?
01-07-2009, 06:06 PM #4
Re: Stench !!
Sorry confused sewer with saw....
Then, yes, look how drainage is done.
01-07-2009, 07:54 PM #5
Re: Stench !!
hopefully there is no refrig leak, than the stench will be gone and the cooling capacity to.
Ice
01-07-2009, 07:55 PM #6
Re: Stench !!
or a mouse or other beasty got trapt in the evaporator and is now rotting in the drippan.......had it ons to.
Ice
01-07-2009, 09:22 PM #7
Re: Stench !!
have they connected the drain to a sewer pipe with out trapping it? try pouring water into the driptray, if smell goes for a while and then returns it probably just needs a trap.
al
01-07-2009, 10:44 PM #8
Re: Stench !!
What sort of unit is it and where is it fitted?
02-07-2009, 02:09 AM #9
Re: Stench !!
I agree with Al, the condensate water trap is probably dry or not deap enough if a negative pressure in fan coil unit, induced draught
02-07-2009, 06:08 AM #10
Re: Stench !!
Have you trapped the drain??
If you have connected the drain to the main drains with no trap your fan could be pulling bad smells up from the drains.
CB
02-07-2009, 01:40 PM #11
Re: Stench !!
Hi all, thank for the many replies...
I'll have my husband to check it all out. We live in a rented appartement, first tenants though... but we haven't put in the airco ourselves so I dont know how it's installed.
It's a Daikin Split System BRC1C61 (anyway that's what it says on the remote controller)
And we do live in Ibiza, when it gets really hot the drains in the bathrooms stink a little bit too. But that's just a little bit and there's not airco unit inthere so that smell shouldn't be able to get into the other units, should it ?
Anyway, thanks again...
02-07-2009, 07:08 PM #12
Re: Stench !!
if the air con is tied to the drains then any smell from the drain will come up.
al
03-07-2009, 03:49 AM #13
Re: Stench !!
If a new apartment , sounds like the plumber was cutting cost and not fitting "s " bends and "P "traps. Your bathroom should not smell at all, let alone the A/C.
PS , very unhealthy to live in that sort of enviroment, all sorts of airbourne nasties, hope you have full medical insurance cover.
