Results 1 to 9 of 9
    Oct 2008
    174
    Brema Ice Machine
    Havent done a lot on ice machines as this may seem like a simple problem, basically as soon as the ice machine is switched on the defrost timer starts going round straight away as if its bypassing the ice thickness stat which is giving the ice no time to make, the ice thickness stat has 3 terminals on it which are all being used (only ones i have looked at have 2, live in and live out when the switch makes), there are no wiring diagrams at all for the defrost timer or the stat so im in the dark. Can anybody tell me what the middle terminal is for on the stat? Basically i need to know if the fault lies with the stat or the timer, i have 240v in on the stat (right spade), 240v on the middle spade and nothing on the left spade yet the timer starts instantly(with the stat turned all the way to the right). Any help will be gratefully appreciated, thanks.
    Jun 2005
    Stoke on Trent
    588
    Re: Brema Ice Machine
    Either a faulty ice thickness stat or someone has fitted the wrong stat.
    11,025
    Can't help with this one sorry, but came across this website when looking for info..
    http://www.acmehowto.com/howto/appli...ker-repair.php
    Might be useful later perhaps.
    Oct 2007
    leeds
    Does the timer actualy go round,or does it just sound like its moving?I had aproblem with the timer failing,it made a noise like it was going round,but wasnt actualy moving,i market it with a pen,and observed for 30secs.Move the timer round manualy(with a srew driver)when it clicks and starts letting water in,observe timer.if it stays letting water in for more that 1min,its the timer.Like i said,mark it with a pen and see if it is actualy moving.I spent ages on a brema,simalar problem.It sounds like its moving,but it ant.
    Oct 2008
    174
    No m8 the timer is going round but problem is that it never stops going round so after hot gas goes through evap coil and cooling cycle starts the timer does a complete circle in like 8 mins which is nowhere near enough time for the ice to form, the thickness stat is supposed to hold off the timer for like 15 mins, just never worked on a thickness stat with 3 terminals before so havent got a clue what the middle one does?
    Oct 2008
    174
    Thanks for the quick replys people , going to replace the stat first and if that dont work then take it back and swap it for a timer, lol
    lebanon
    130
    hi
    u said that u by passed the stat and that is wrong
    u should know first how it works
    the timer motor remain stop unlessthe evaporator reaches -10c then the stat energizes timer motor
    when timer reaches harvest point timer motor stops again its energized when evaporator reaches around 8cthen the contact u asking forenergizes timer motor to complete harvest and stops cooling starts again when evaporator reaches -10 timer starts to turn again
    hope that helps
    ur problem is solved by changing stat
    Aug 2010
    Australia
    8
    Do we know if that worked?
    Aug 2010
    Australia
    8
    Seems like it's always tough to tell the difference between a stat and a timer problem.
  1. Replies: 15
    Last Post: 02-01-2011, 01:26 AM
  2. brema ice machine
    By WARDYBOY in forum Trouble Shooting
    Last Post: 27-01-2009, 08:18 PM
  3. elmeco slushy machine
    By Temprite in forum Commercial
    Last Post: 14-09-2008, 08:58 AM
  4. Brema Ice Machine
    By homeire in forum Trouble Shooting
    Last Post: 25-07-2008, 10:43 PM
  5. Cattabriga Ice Cream Machine
    By Abe in forum Trouble Shooting
    Last Post: 26-04-2003, 01:06 PM
