    India
    688
    wall panel supports - cold stores
    Long wall panels which need to be supported from outside, there are many options & designs available. What is the cost effective & simple solution for this?
    Sep 2006
    Venezuela
    259
    Re: wall panel supports - cold stores
    Hello smpsmp45
    The outside support depend on the many factors
    The hight of the walls
    The type of panel ,with channels or plane
    The thinkes of the panels
    The cover sheet of the panel Metal or fiber
    It will be located outside or inside
    What is the speed velocity of the wind against the walls
    Gwapa
    India
    688
    Well it seems you have done a lot of exercise on this. I had referred to various ways offered by companies like ISOCAB. KINGSSPAN ISOPOLI etc. But anyway
    The hight of the walls 12.5 Outside / Inside clear 11.62
    The type of panel ,with channels or plane - With Corrugations
    The thinkes of the panels - 170mm
    The cover sheet of the panel Metal or fiber - 0.6mm Precoated sheets
    It will be located outside or inside Outside
    What is the speed velocity of the wind against the walls No Idea. You can consider Best / Worst Scene for location in Indonesia
    Sep 2006
    Venezuela
    259
    Dear smpsmp45
    We are making already a similar one
    The worst outer wind is 80 Km/h in our zone close to the coast see . Also it is located in a zone of earthqueak 5 (you should also consider )
    We are supporting the panel at 4 m and 8 m hight
    We fix the panels to the outer structure (at 4 and 8 m) with an special nylon screw M10
    Hope this help
    Regards Gwapa
    Oct 2003
    5,630
    Smpsmp, Isocab is a Belgium company situated 35 miles from me.
    Are those used in you country?
    I have an Isocab manual with all sort of different attachments methods in it for their panels.
    Will have a look for you.
    It is in Dutch and I got it from an Isocab technician which they use it on site.
    Oct 2003
    5,630
    SmpSmp
    I have something but it is too big to post here.
    Send me a PM
  1. Fresh air in the Cold stores
    By smpsmp45 in forum NH3
    Last Post: 09-05-2009, 01:20 AM
  2. Cold Store Panel
    By snow_man in forum Trouble Shooting
    Last Post: 31-07-2008, 08:05 AM
  3. Replies: 1
    Last Post: 10-07-2008, 09:06 AM
  4. Multiple ref. units for cold stores
    By smpsmp45 in forum Commissioning
    Last Post: 21-06-2007, 06:02 PM
  5. lighting in cold stores
    By smpsmp45 in forum Electrical
    Last Post: 29-05-2007, 01:57 PM
